29 กันยายน 2024, 22:32:59 *
ผู้เขียน หัวข้อ: ชุดบอร์ดควบคุมเครื่อง CNC 3 Axis ราคาแค่ 3900-  (อ่าน 2615 ครั้ง)
hansols
กระทู้: 518
« เมื่อ: 30 กรกฎาคม 2011, 19:14:17 »
<a href="http://www.youtube.com/watch?v=HHcNqK0ZrT8" target="_blank">http://www.youtube.com/watch?v=HHcNqK0ZrT8</a>
<a href="http://www.youtube.com/watch?v=rsovhgOTXb0" target="_blank">http://www.youtube.com/watch?v=rsovhgOTXb0</a>
 Product Features:
Toshiba TB6560AHQ chip - High power, maximum 3.5A drive current chipset !
For TB6560AHQ Datasheet, Please click here.
1-1/16 microstep setting - Higher accuracy and smoother operation than standard 1, 1/2 step!
Adjustable 1.5A-3A drive current settings for each axis - 25%,50%,75%,100% of full current can be set for different stepper motors
Overload, over-current and over-temperature safety - Full protection for your computer and peripheral equipment !
On board current switching - Power output can be set according to specific user requirement !
Full closed-type optical isolation to protect the user's computer and equipment
Relay spindle interface - Outputs Max. 36V 7.5A for spindle motors or coolant pump (only one device can be powered by this output!)
4 channel inputs interface- Can be used for XYZ limit and emergency stop !
Professional design - Two stage signal processing with super anti-jamming !
Bipolar constant current chopper drive with non-resonant region - Controls motors smoothly through range without creep effect !
Four control inputs (divided into pairs of knives) - Allows setting of limit and emergency stop !
Universal architecture - Supports most parallel software MACH3,KCAM4 etc!
*For compatibility with other softwares, please feel free to contact us!
Further Details:
Power supply DC 12-36V (not included, please feel free to contact us if you need !)
*Voltage Selection:
12-16V DC power supply for Nema 17 stepper motors
16-24V DC power supply for Nema 23 stepper motors
24-36V DC power supply for Nema 34 stepper motors
(High voltage will burn up the chips or stepper motors!!!)
The power output of 12V shall be applied to the radiator fan of 12V
Driver output compatible with 2 or 4 phase, 4,6 or 8 lead stepper motors, 3A max.
Suitable for unipolar or bipolar stepper motors.
Voltage regulated spindle speed controlled by parallel interface as function of supply volta
Dip settings:
Current Setting 1 2 Decay Mode Settings 3 4 MicroStep Settings 5 6
100% ON ON FAST ON ON 1 ON ON
75% ON OFF 25% ON OFF 1/2 ON OFF
50% OFF ON 50% OFF ON 1/8 OFF OFF
25% OFF OFF SLOW OFF OFF 1/16 OFF ON
คู่มือ
Download คลิกที่นี่
ความฝันของคนงบน้อยที่อยากมีเครื่อง CNC ไว้ใช้งานคนไทยช่วยคนไทยครับ  ยิงฟันยิ้ม
Tel : 086-721 - 4 - ศูนย์ - ศูนย์ - ศูนย์ truemove
mail : ood_my (แอด) hotmail . คอม
( ประเทศไทย )
