04 กรกฎาคม 2024, 07:32:39 *
ผู้เขียน หัวข้อ: ผมไปเจอตัวนี้มา ท่านใดช่วยไขหน่อย มันเปิดแบนด์ได้ถึงไหน  (อ่าน 2366 ครั้ง)
wim
กระทู้: 5291
HS3ZEG
« เมื่อ: 16 มิถุนายน 2011, 20:12:55 »
Modifications for the Kenwood TH-28
Secret function manual of the KENWOOD TH-28e/48e
u>TH-28e/48e RX EXPANSION (ON)
Press PTT + VFO, then POWER ON.
New RX ranges TH28e after this modification:
VHF Band 136 - 174 Mhz (FM)
UHF Band 400 - 520 Mhz (FM)
TH48e:
UHF Band 400 - 470 Mhz (FM)
TH28e Air Band Expansion
Press F key for 1 sec. Then press LOW key.
New RX ranges
108 - 118 Mhz (FM)
118 - 136 Mhz (AM)
TH28e 340 - 400 Mhz Expansion
Remove the diode D8 from the control unit. (FM mode only) With Air Band and 340 Mhz expansion, operating band can be changed:
           _________      _________      __________
     ---->I AMATEUR I====I 340 Mhz I--->I AIR BAND I_____
     I    I_________I    I_________I    I__________I     I
     I___________________________________________________I
TH48e 340 MHZ & 900 MHZ EXPANSION
Remove the diode D8 from the control unit to cover 340 - 400 Mhz and 800 - 950 Mhz FM mode.
      --->I AMATEUR I--->I 340 Mhz I--->I 900 Mhz I_____
     I    I_________I    I_________I    I_________I     I
     I__________________________________________________I
TH-28e/48e TX EXPANSION
Remove the diode D10 from the control unit.
New TX ranges after this modification:
TH28e:
VHF Band 136.000 - 174.250 Mhz (FM)
TH48e:
UHF Band 400.000 - 470.000 Mhz (FM)
Note:
Manufacturer guarantees TX/RX specification only in amateur band. The above frequency range is for the microprocessor's range so that the receiver sensitivity or TX output power of expanded band may be reduced.
TH-48E TX/RX 432-438 Mhz LIMITED RANGE
Remove the diode D14 from the control unit.
TH28e/48e CROSS BAND REPEATER
Remove the diode D4 then press F key for 1 sec. and press 0 key.
TH-28a/e-48a/e FREQUENCY EXTENSION
Open the case and remove or add the destination chip diode D10, D11, D14 and D15 on the component side of the control unit.
(X53-340X-XX, X53-341X-XX)
The frequncy can then be extended as shown in the table 1 an 2 on page 3 and 4.(See the destination chip diode position drawing on the attached sheet.)
http://www.radiomods.co.nz/kenwood/kenwoodth28.html
wim
กระทู้: 5291
HS3ZEG
« ตอบ #1 เมื่อ: 16 มิถุนายน 2011, 20:16:10 »
การปรับเปลี่ยนสำหรับ KENWOOD TH - 28
คู่มือฟังก์ชั่นความลับของ KENWOOD TH-28e/48e
u> ขยาย TH-28e/48e RX (ON)
ปตท. + กด VFO, POWER ON แล้ว
RX ใหม่ TH28e ช่วงหลังการแก้ไขนี้ :
VHF Band 136-174 MHz (FM)
UHF Band 400-520 MHz (FM)
TH48e :
UHF Band 400-470 MHz (FM)
TH28e ขยายวงแอร์
กด F ที่สำคัญสำหรับ 1 วินาที จากนั้นกดคีย์ต่ำ
RX ใหม่ช่วง
108 - 118 Mhz (FM)
118-136 MHz (PM)
TH28e 340 -- 400 MHz การขยายตัว
ลบ D8 ไดโอดจากหน่วยควบคุม (โหมดเอฟเอ็มเท่านั้น) กับวงอากาศและการขยายตัว Mhz 340, วงปฏิบัติการสามารถเปลี่ยนแปลงได้ :
     ----> ผม AMATEUR ฉัน ==== ผม 340 Mhz ผม ---> BAND ฉัน AIR I_____
     ผม I_________I I_________I I__________I ฉัน
340 MHZ TH48e & EXPANSION 900 MHz
ลบ D8 ไดโอดจากหน่วยควบคุมเพื่อให้ครอบคลุม 340 - 400 MHz และ 800 - 950 Mhz FM โหมด
      ---> ฉัน AMATEUR ผม ---> ผม 340 Mhz ผม ---> ผม 900 MHz I_____
     ผม I_________I I_________I I_________I ฉัน
ขยาย TH-28e/48e เท็กซัส
ลบไดโอด D10 จากหน่วยควบคุม
ใหม่เท็กซัสในช่วงหลังการแก้ไขนี้ :
TH28e :
VHF Band 136.000-174.250 MHz (FM)
TH48e :
UHF Band 400.000-470.000 MHz (FM)
หมายเหตุ :
ข้อกำหนดการค้ำประกันผู้ผลิต TX / RX เฉพาะในวงดนตรีสมัครเล่น ช่วงความถี่ดังกล่าวเป็นช่วงของไมโครโปรเซสเซอร์เพื่อให้ความไวในการรับหรืออำนาจออกเท็กซัสของวงขยายตัวอาจจะลดลง
TH - 48E TX / RX 432-438 Mhz จำกัด ประเภท
ลบไดโอด D14 จากหน่วยควบคุม
TH28e/48e BAND REPEATER CROSS
ถอดไดโอด D4 แล้วกดคีย์ F 1 วินาทีสำหรับ กด 0 และที่สำคัญ
EXTENSION ความถี่ TH-28a/e-48a/e
กรณีเปิดและลบออกหรือเพิ่มไดโอดชิปปลายทาง D10, D11, D14 และ D15 ในด้านองค์ประกอบของหน่วยควบคุม
(X53 - 340X - XX, X53 - 341X - XX)
frequncy นั้นจะสามารถขยายดังแสดงในตารางที่ 1 2 หน้า 3 และ 4. (ดูปลายทางชิปไดโอดตำแ​​หน่งการวาดภาพบนแผ่นกระดาษที่แนบมา.)
hs5xld
กระทู้: 977
« ตอบ #2 เมื่อ: 17 มิถุนายน 2011, 09:27:13 »
แล้วได้คำตอบหรือยังครับ
เห็นถามแล้วก็แปล แล้วได้เรื่องถึงไหนแล้วครับพี่น้อง
สมชาย ใจบุญเรือง
ธนาคารกสิกรไทย
สาขาลาดพร้าว 25
045-2-93296-2
http://www.radioamateur.eu
wim
กระทู้: 5291
HS3ZEG
« ตอบ #3 เมื่อ: 17 มิถุนายน 2011, 12:57:02 »
ผมลองทำแล้วได้บ้างไม่ได้บ้าง ปุ่ม VFO ผมเสีย อีกอย่างยังไม่ได้แกะถอดไดโอดดูครับ พักนี้ยุ่งๆอยู่ พ่อก็มาป่วยเลยได้แค่นี้ครับ
