hondaone
ออฟไลน์
กระทู้: 12747
0886074166 HONDAONE
« ตอบ #16 เมื่อ: 04 พฤษภาคม 2011, 11:56:42 » |
Quick Specs: Single sideband radiotelephone RX: 1.6 MHz-23.9999 MHz TX: marine HF bands (see detailed specifications) Output power: 150 W Modes: USB, LSB Features
Smooth sailing ahead with this all mode marine transceiver
150 W output power Icom introduces the IC-M700, a full-featured 150 W HF transceiver that will keep you in touch at all times with the shore and other vessels.
Easy operation Channel selection can be quickly and easily performed with the CHANNEL GROUP and CHANNEL SWITCHES.
Full coverage The IC-M700 features full transmit and receive coverage of all marine bands through 2.000~22.9999 MHz. The IC-M700 covers all ship-to-shore frequencies using simplex or semi-duplex mode.
General coverage receiver The IC-M700 provides general coverage receiving through 1.6000~23.9999 MHz. You can receive news broadcasts such as UPI and AP, weather reports, WWV time signals, FAX weather charts, foreign broadcasts, etc.
PLL circuit A quartz-locked synthesized tuning system provides superb stability without you ever having to purchase expensive crystals or PROMs.
48 memory channels 48 memory channels are easily programmed with the keyboard on the front panel. Independent transmit and receive frequency programming provides complete flexibility.
All mode capability High seas transmission is possible in J3E, R3E and H3E modes.
Automatic antenna tuner The optional AT-120 HF AUTOMATIC ANTENNA TUNER matches a wide range of antenna impedances. For example, the tuner will match a 7-meter (23 feet) long-wire antenna through 2~23 MHz.
2182 kHz safety signal When an optional UT-20 ALARM UNIT is installed, 2182 kHz international safety signals can be transmitted if your ship is in distress.
Handset The optional IC-HS2 HANDSET KIT is perfect for communicating during difficult offshore conditions. The IC-HS2 is also great for listening privacy on board. Detailed Specifications GENERAL
Frequency Coverage: Transmit 2.0000~2.9999 MHz, 4.0000~4.9999 MHz, 6.0000~6.9999 MHz, 8.0000~8.9999 MHz, 12.0000~13.9999 MHz, 16.0000~17.9999 MHz, 22.0000~22.9999 MHz; Receive 1.6000~23.9999 MHz Modes: A3J (J3E; USB, LSB), A3A (R3E; USB), A3H (H3E; USB) Number of Channels: 48 Antenna Impedance: 50 - unbalanced Power Supply Requirement: 13.6 V DC +/-15% (negative ground) Current Drain (at 13.6 V DC): Transmit, Average voice 12 A, Two tone 19A; Receive, Squelched 1.2 A, Max. audio output power 1.6 A Usable Temperature Range: -30°C~ to +60°C Frequency Stability: +/-20 Hz (-30°C~ to +60°C) Dimensions: 287(W) x 112(H) x 356(D) mm; 11.3(W) x 4.4(H) x 14.0(D) in (projections not included) Weight: 7.2 kg; 15.9 lb TRANSMITTER
Output Power: 150 W (PEP) Modulation System: J3E, R3E Balanced modulation; H3E Low power modulation Spurious Emissions: 65 dB below peak output power Carrier Suppression: J3E, 40 dB below peak output power; R3E, 16 dB +/-2 dB below peak output power; H3E, 3~6 dB below peak output power Unwanted Sideband: 55 dB below peak output power Microphone Impedance: 600 ohms RECEIVER
Receiver System: Double-conversion superheterodyne Intermediate Frequencies: 1st 70.4515 MHz (J3E, R3E), 70.4500 MHz (H3E); 2nd 9.0115 MHz (J3E, R3E),9.0100 MHz (H3E) Sensitivity: J3E, R3E 0.5 µV for 12 dB SINAD, H3E 1.4 µV for 12 dB SINAD Selectivity: J3E, R3E 2.3 kHz/-6 dB, 4.2 kHz/-60 dB; H3E 6 kHz/-6 dB, 20 kHz/-60 dB Spurious Response and Image Rejection: 70 dB Audio Output Power: 5 W with a 4 ohm load Audio Output Impedance: 2~8 ohm IC-M700 Options
AT-130 HF AUTOMATIC ANTENNA TUNER IC-HS2 HANDSET KIT MN-100 ANTENNA MATCHER (for dipole or whip antennas) MN-100L ANTENNA MATCHER (for whip or wire antennas) PS-60 AC POWER SUPPLY (13.6 V, 30 A) PS-65 DC-DC CONVERTER (input 10.5~16 V output 13.6 V, 30 A) PS-66 DC-DC CONVERTER (input 19~32 V output 13.6 V, 30 A) UT-20 ALARM UNIT
