22 กันยายน 2024, 09:05:39 *
ผู้เขียน หัวข้อ: HF ICOM IC-M700 สวยๆ ประมูลกันไปเลย  (อ่าน 3042 ครั้ง)
hondaone
กระทู้: 12747
0886074166 HONDAONE
« เมื่อ: 03 พฤษภาคม 2011, 22:08:10 »
ประมูล กันไปเลย เริ่มเปิดที่ราคา 5500 เคาะครั้งละไม่ต่ำกว่า50บาท ปิด 22.30 วันนี้ 4-5-2011 ใส่เบอร์โทรไว้ด้วย   ออกค่าส่งเองนะครับอีก300บาท
ลุยกันเลย
HF ICOM IC-M700
http://www.icomcanada.com/archive/marine/ic-m700.htm
IC-M700 - Single Sideband Radiotelephone
Quick Specs:
Single sideband radiotelephone
RX: 1.6 MHz-23.9999 MHz
TX: marine HF bands (see detailed specifications)
Output power: 150 W
Modes: USB, LSB
Features
Smooth sailing ahead with this all mode marine transceiver
150 W output power
Icom introduces the IC-M700, a full-featured 150 W HF transceiver that will keep you in touch at all times with the shore and other vessels.
Easy operation
Channel selection can be quickly and easily performed with the CHANNEL GROUP and CHANNEL SWITCHES.
Full coverage
The IC-M700 features full transmit and receive coverage of all marine bands through 2.000~22.9999 MHz. The IC-M700 covers all ship-to-shore frequencies using simplex or semi-duplex mode.
General coverage receiver
The IC-M700 provides general coverage receiving through 1.6000~23.9999 MHz. You can receive news broadcasts such as UPI and AP, weather reports, WWV time signals, FAX weather charts, foreign broadcasts, etc.
PLL circuit
A quartz-locked synthesized tuning system provides superb stability without you ever having to purchase expensive crystals or PROMs.
48 memory channels
48 memory channels are easily programmed with the keyboard on the front panel. Independent transmit and receive frequency programming provides complete flexibility.
All mode capability
High seas transmission is possible in J3E, R3E and H3E modes.
Automatic antenna tuner
The optional AT-120 HF AUTOMATIC ANTENNA TUNER matches a wide range of antenna impedances. For example, the tuner will match a 7-meter (23 feet) long-wire antenna through 2~23 MHz.
2182 kHz safety signal
When an optional UT-20 ALARM UNIT is installed, 2182 kHz international safety signals can be transmitted if your ship is in distress.
Handset
The optional IC-HS2 HANDSET KIT is perfect for communicating during difficult offshore conditions. The IC-HS2 is also great for listening privacy on board.
Detailed Specifications
GENERAL
•Frequency Coverage: Transmit 2.0000~2.9999 MHz, 4.0000~4.9999 MHz, 6.0000~6.9999 MHz, 8.0000~8.9999 MHz, 12.0000~13.9999 MHz, 16.0000~17.9999 MHz, 22.0000~22.9999 MHz; Receive 1.6000~23.9999 MHz
•Modes: A3J (J3E; USB, LSB), A3A (R3E; USB), A3H (H3E; USB)
•Number of Channels: 48
•Antenna Impedance: 50 - unbalanced
•Power Supply Requirement: 13.6 V DC +/-15% (negative ground)
•Current Drain (at 13.6 V DC): Transmit, Average voice 12 A, Two tone 19A;
•Receive, Squelched 1.2 A, Max. audio output power 1.6 A
•Usable Temperature Range: -30°C~ to +60°C
•Frequency Stability: +/-20 Hz (-30°C~ to +60°C)
•Dimensions: 287(W) x 112(H) x 356(D) mm; 11.3(W) x 4.4(H) x 14.0(D) in (projections not included)
•Weight: 7.2 kg; 15.9 lb
TRANSMITTER
•Output Power: 150 W (PEP)
•Modulation System: J3E, R3E Balanced modulation; H3E Low power modulation
•Spurious Emissions: 65 dB below peak output power
•Carrier Suppression: J3E, 40 dB below peak output power; R3E, 16 dB +/-2 dB below peak output power; H3E, 3~6 dB below peak output power
•Unwanted Sideband: 55 dB below peak output power
•Microphone Impedance: 600 ohms
RECEIVER
•Receiver System: Double-conversion superheterodyne
•Intermediate Frequencies: 1st 70.4515 MHz (J3E, R3E), 70.4500 MHz (H3E); 2nd 9.0115 MHz (J3E, R3E),9.0100 MHz (H3E)
•Sensitivity: J3E, R3E 0.5 µV for 12 dB SINAD, H3E 1.4 µV for 12 dB SINAD
•Selectivity: J3E, R3E 2.3 kHz/-6 dB, 4.2 kHz/-60 dB; H3E 6 kHz/-6 dB, 20 kHz/-60 dB
•Spurious Response and Image Rejection: 70 dB
•Audio Output Power: 5 W with a 4 ohm load
•Audio Output Impedance: 2~8 ohm
IC-M700 Options
•AT-130 HF AUTOMATIC ANTENNA TUNER
•IC-HS2 HANDSET KIT
•MN-100 ANTENNA MATCHER (for dipole or whip antennas)
•MN-100L ANTENNA MATCHER (for whip or wire antennas)
•PS-60 AC POWER SUPPLY (13.6 V, 30 A)
•PS-65 DC-DC CONVERTER (input 10.5~16 V output 13.6 V, 30 A)
•PS-66 DC-DC CONVERTER (input 19~32 V output 13.6 V, 30 A)
•UT-20 ALARM UNIT
อุปกรณ์ตามรูปยังไม่ได้ทำความสะอาด เครื่องรับส่งปรกติ DC TYPE 150watts  ขาย 9000    0886074166
« แก้ไขครั้งสุดท้าย: 04 พฤษภาคม 2011, 10:29:34 โดย hondaone » บันทึกการเข้า
0886074166 HONDAONE
hondaone
กระทู้: 12747
0886074166 HONDAONE
« ตอบ #1 เมื่อ: 03 พฤษภาคม 2011, 23:01:15 »
ก่อนนอน
manus65
กระทู้: 3047
はじめまして。
« ตอบ #2 เมื่อ: 03 พฤษภาคม 2011, 23:09:48 »
ถ้าสัก 7000 น่าสน  ขยิบตา
สาวก 2N
MR.BOY
กระทู้: 2878
ตู้ ปณ.123 ปณจ.จันทบุรี 22000
« ตอบ #3 เมื่อ: 03 พฤษภาคม 2011, 23:14:42 »
ต่อไฟให้เห็นหน้าจอหน่อยครับ แสดงความถี่หรือช่องความจำ
ที่ทำให้คนรุ่นใหม่ลืมวงการนี้
kobnikala
กระทู้: 393
E22YEP Ham Chiangmai Thailand
« ตอบ #4 เมื่อ: 03 พฤษภาคม 2011, 23:23:42 »
ว้าว งามมมมมม ไม่เคยเห็น แร่ไหม หรือใช้คอมตั้ง หรือ ไซเซอร์ เห่อๆๆๆ งาม ๆ ๆ
153RT450"นักวิทยุเถื่อนขั้นสูงป๋ายป๊าว"
ดาบอ๊บ 191 เชียงใหม่ 086-4267431
พร้อมเพย์ 0864267431
e-mail:153rt450(แอท)gmail.com
hondaone
กระทู้: 12747
0886074166 HONDAONE
« ตอบ #5 เมื่อ: 03 พฤษภาคม 2011, 23:43:10 »
ตั้งหน้าเครื่องเลยกดตรงที่ปิดกระจกครับแมมได้36ช่อง
hondaone
กระทู้: 12747
0886074166 HONDAONE
« ตอบ #6 เมื่อ: 03 พฤษภาคม 2011, 23:48:25 »
ไม่ได้เอาสายไฟมาครับ รูปแทน
hondaone
กระทู้: 12747
0886074166 HONDAONE
« ตอบ #7 เมื่อ: 04 พฤษภาคม 2011, 00:26:26 »
นอนละครับ
hondaone
กระทู้: 12747
0886074166 HONDAONE
« ตอบ #8 เมื่อ: 04 พฤษภาคม 2011, 05:58:43 »
มีเพื่อนสมาชิกต่อราคาไว้ที่7000    ร้องไห้ ร้องไห้ ขายที่7000ครับ
« แก้ไขครั้งสุดท้าย: 04 พฤษภาคม 2011, 09:24:04 โดย hondaone » บันทึกการเข้า
hondaone
กระทู้: 12747
0886074166 HONDAONE
« ตอบ #9 เมื่อ: 04 พฤษภาคม 2011, 09:24:31 »
