02 ตุลาคม 2024, 19:31:20 *
ผู้เขียน หัวข้อ: ปิดการขาย Sony ICF-2001D วิทยุรับ Worldband  (อ่าน 1387 ครั้ง)
HS1ZRH
กระทู้: 350
Vientiane, Lao
« เมื่อ: 19 ธันวาคม 2010, 13:22:13 »
ปิดการขายครับ เจ้าของใหม่มารับไปดูแลเรียบร้อยแล้วครับ ขาย Sony ICF-2001D
วิทยุรับ Worldband สภาพใหม่เก่าเก็บ
SONY ICF-2001D SPECIFICATIONS
ICF-2001D: AEP, UK, E, AUS models
  Circuit System FM Superheterodyne
  AIR/AM Dual conversion superheterodyne
Frequency Range AIR 116 - 136 MHz (Except Middle East, Saudi Arabia, UK, Denmark, Finland, Norway, Federal Republic of Germany)
  FM 76 - 108 MHz ((US. Canadian, E (Except Middle East. Saudi Arabia), AEP (Except Federal Republic of Germany. France, Denmark, Norway and Finland), UK, AUS))
87.5 - 108 MHz (E (Middle East, Saudi Arabia). AEP (France. Denmark, Norway, Finland, Federal Republic of Germany))
  AM 150 - 29999.9kHz (US, Canadian, E (Except Middle East, Saudi Arabia). AEP (Except Federal Republic of Germany), AUS, UK)
150 - 26.100 kHz (E (Middle East), AEP (Federal Republic of Germany))
150 - 285 kHz and 530 - 26.100 kHz (E (Saudi Arabia))
Antennas AIR/FM/SW Telescopic antenna. External antenna terminal for AM (LW/MW/SW)
  MW/LW Built-in ferrite bar antenna. External antenna terminal for AIR/FM as appropriate.
Speaker   Approx. 10 cm (4 inches) diameter 380 mW (at 10% harmonic distortion). Recording output jack (minijack). Output level 0.775 mV (-60 dB). Output impedance 1 kilohm. Earphone jack (minijack)
Power  Radio 4.5 V DC. Three size D batteries (IEC designation R20). DC IN 4.5V jack accepts: Supplied ac power adaptor for use on 120 V AC, 60 Hz.
Optional DCC-127A car battery cord for use with 12 V car battery (Except AUS).
  Computer/ clock 3 V DC two size AA batteries (IEC designation R6).
Battery Life  Radio The battery life assumes listening to the radio for four hours a day at normal volume
Approx. 40 hours (FM reception). Approx. 30 hours (AM/AIR reception) using Eveready No. 1250 batteries.
  Computer/ clock Approx. 1 year using Eveready No. 1015 batteries.
« แก้ไขครั้งสุดท้าย: 24 ธันวาคม 2010, 20:33:19 โดย HS1ZRH » บันทึกการเข้า
วาสิษฐ์พล
โทร. +66 9 9625 5335
HS1ZRH
กระทู้: 350
Vientiane, Lao
« ตอบ #1 เมื่อ: 20 ธันวาคม 2010, 00:18:23 »
ตกไปหลายหน้า ขออัพหน่อยครับ
HS1ZRH
กระทู้: 350
Vientiane, Lao
« ตอบ #2 เมื่อ: 20 ธันวาคม 2010, 10:50:58 »
up
HS1ZRH
กระทู้: 350
Vientiane, Lao
« ตอบ #3 เมื่อ: 21 ธันวาคม 2010, 11:16:55 »
up
HS1ZRH
กระทู้: 350
Vientiane, Lao
« ตอบ #4 เมื่อ: 22 ธันวาคม 2010, 11:10:57 »
อัพสายๆ
yuthana.sw
กระทู้: 3
« ตอบ #5 เมื่อ: 23 ธันวาคม 2010, 00:01:23 »
จองเลยนะครับ ขอบคุณครับพี่เอาของมาให้ดูถึงที่เลย ยังไงถ้าทันก็จะรีบรับของก่อน 25 ตอนเช้านะครับ
HS1ZRH
กระทู้: 350
Vientiane, Lao
« ตอบ #6 เมื่อ: 23 ธันวาคม 2010, 02:02:00 »
ด้วยความยินดีครับ ขอบคุณครับ
