25 พฤศจิกายน 2024, 11:07:24 *
หน้า: [1] 2 3 ... 5
ผู้เขียน หัวข้อ: ___ แค่590 เป็นดีเจ มือโปร ง่ายๆด้วย iphone/ipad + สาย Griffin DJ สำหรับแอพ DJay  (อ่าน 16684 ครั้ง)
TM-241
กระทู้: 4047
« เมื่อ: 17 มิถุนายน 2021, 12:51:30 »
สาย Griffin DJ Cable for iphone ipad ipod สำหรับแยกเสียงหูฟังกับลำโพง ในการใช้แอพ djay
https://griffin.zendesk.com/hc/en-us/article_attachments/203497324/P4971_DJcable_ts.pdf
The Griffin Technology DJ Cable is designed to be used with iOS mobile devices and enables the Split Output function when using the djay algoriddim app. With Split Output mode enabled, djay sends the master output to the left channel, and the cue output to the right channel. This lets you cue songs through your headphones independently of the mix that's going through the speakers. The cable has connectors for the speaker system, headphones and audio jack for your device.
For iOS mobile devices - enables Split Output when using djay app
Splitter cable allows you to hear the speaker mix and the song being cued up
Connectors for speaker system, headphones and audio jack on your iOS device
Pre-Cueing
Previewing with headphones
The ability to pre-cue, or preview, the next track through your headphones is essential for any DJ to seamlessly mix the currently playing track into the next track. This allows for finding the perfect next track, flawless beatmatching, and creating a mix customized for your crowd.
In djay, there are two ways you can pre-cue your tracks: by using the Split Output function paired with a stereo/mono DJ split cable, or by connecting an external sound card or DJ controller.
A proper DJ split cable lets you cue up the next track in your headphones independently from what the crowd is currently hearing from the speakers, allowing for a smooth mix.
DJ split cables can be enabled through djay’s Split Output function for pre-cueing. Optimal features you want to look for are gold-plated connectors for improved conductivity and better signal, as well as a durable exterior for longevity.
Note: A DJ split cable splits your stereo jack into two mono channels. This means your speaker output using this setup will always be mono (using two duplicate mono output channels).
รายละเอียดสินค้า
อุปกรณ์เสริมสำหรับ ipad, iphone, ipod touch เพื่อใช้เชื่อมกับโปรแกรม DJ สามารถแยกเสียงหูฟังกับลำโพงได้ ของมือ1 เก่าเก็บ
ซื้อมาพันกว่าบาท ขาย 950 ฿
ลดเหลือ 590 รวมส่ง ภายใน 31/03/65
สนใจโทร 0869455977
หรือ Line ID: ctek.thai
CISCO SG95-24-AS Gigabit L2 Switch Hub 24 Port (11'') ประกัน LT แค่ 4xxx
อุปกรณ์กิกะบิตสวิทช์ 24 พอร์ท 10/100/1000 Mbps แบบ RJ-45 + 2 พอร์ท Combo GbE (SFP) เลือกใช้งานระหว่าง RJ-45 หรือ SFP
รองรับการงาน L2 เหมาะสำหรับใช้งานเพื่อเชื่อมต่อ ระบบเครือข่ายความเร็วสูงมาก
สวิตซ์ SG95-24 มี 24 พอร์ต Gigabit Ethernet และ 2 พอร์ต Mini-GBIC Combo รองรับการเชื่อมต่อสาย Fiber Optic, ความเร็วรับส่งข้อมูลรวม 10 Gbps (Switching Capacity)
มีไฟแสดงสถานะ Link และ Active ตัวเครื่องเป็นโลหะแข็งแรงทนทาน รองรับติดตั้งแบบแขวนในตู้ Rack เหมาะสำหรับเชื่อมต่ออุปกรณ์เครือข่ายคอมพิวเตอร์จำนวนมากด้วยความเร็วสูงมาก
Data Sheet for Cisco SG95-24
http://sys2u.com/download/20160316-180624-cisco-switch-smb95-series-datasheet.pdf
ประเภทอุปกรณ์
   อุปกรณ์กิกะบิตสวิทช์ 24 พอร์ท 10/100/1000 Mbps แบบ RJ-45 + 2 พอร์ท Combo GbE (SFP) เลือกใช้งานระหว่าง RJ-45 หรือ SFP, รองรับการงาน L2 เหมาะสำหรับใช้งานเพื่อเชื่อมต่อ ระบบเครือข่ายความเร็วสูงมาก
การนำไปใช้งาน
   สำหรับใช้งานในบ้านหรือสำนักงาน เพื่อเชื่อมต่อระบบเครือข่าย ที่ต้องการความเร็วสูงมาก
พอร์ท LAN
   24 กิกะบิทพอร์ท 10/100/1000 แบบ RJ-45 สำหรับเชื่อมต่อระบบแลน
รองรับการทำงาน Auto MDI/MDI-X, Half/Full Duplex Mode
พอร์ท SFP
   2 พอร์ท Combo (SFP) เลือกใช้งานได้ระหว่างพอร์ท RJ-45 และ SFP ความเร็ว 10/100/1000 Mbps สำหรับขยายการเชื่อมต่อ
เทคโนโลยี
   Advanced Store-and-Forward Packet Switching, Non-blocking
ขนาด / น้ำหนัก
   279.4 x 44.45 x 170 มม / 1,630 กรัม
ราคาของใหม่ เบิกห้างต้องจ่าย 7xxx รวม vat   -->> https://www.sysinfo.co.th/sg95-24-as.html
ตัวนี้สินค้าใหม่ไม่เคยใช้งาน ประกัน LT (เทสแล้วใช้งานปกติทุกพอร์ท)
ย้ายออฟฟิศกล่องหาย มีตัวเครื่อง เอกสาร สายไฟac ขายแค่ 4890 พร้อมส่ง flash ฟรีทั่วไทย
สนใจโทร 0869455977
« แก้ไขครั้งสุดท้าย: 24 มีนาคม 2022, 18:55:34 โดย TM-241 » บันทึกการเข้า
**หมายเหตุ**
TM-241
กระทู้: 4047
« ตอบ #1 เมื่อ: 18 มิถุนายน 2021, 10:18:38 »
จาก แสนกว่าขาย 2x,xxx เครื่องเล่น PIONEER CDJ-800+มิกซ์ดีเจ 4CH DJM-600+CASE
ขายเครื่องเล่น PIONEER CDJ-800 + มิกซ์ดีเจ 4-CH DJM-600 + Flightcase สภาพดี ใช้งานน้อย
CDJ-800  ของใหม่ 29,000฿  -> https://www.pioneerdj.com/en/product/player/archive/cdj-800/silver/overview/
มิกซ์ดีเจ 4-CH DJM-600 ราคาของใหม่ 42,800฿ ->  http://www.mynke.com/%E0%B9%80%E0%B8%84%E0%B8%A3%E0%B8%B7%E0%B9%88%E0%B8%AD%E0%B8%87%E0%B9%80%E0%B8%AA%E0%B8%B5%E0%B8%A2%E0%B8%87%E0%B8%81%E0%B8%A5%E0%B8%B2%E0%B8%87%E0%B9%81%E0%B8%88%E0%B9%89%E0%B8%87-PA/MIXER-DJ/MIXER-DJ-PIONEER/%E0%B8%A1%E0%B8%B4%E0%B8%81%E0%B8%8B%E0%B9%8C%E0%B8%94%E0%B8%B5%E0%B9%80%E0%B8%88-4-CHANNEL-EFFECTS-MIXER-PIONEER-DJM-600.html
ซื้อมาทั้งชุดแสนกว่าบาท สภาพดีตามรูป ใช้น้อย ใช้งานใด้ปกติทุกปุ่มทุกฟังค์ชั่น พร้อมกล่องแท้ติดเครื่องมา ตอนส่งแพคกิ้งอย่างดีไม่ต้องกลัวแตกหักเสียหาย
ราคาขายแยกตามนี้ครับ
CDJ-800 x 2 ตัว ราคาตัวละ 5800 ฿ รวมส่ง
DJM-600 x 1 ตัว ราคาตัวละ 16900 ฿ รวมส่ง
Flight case สำหรับใส่ เครื่องเล่น+มิกซ์  ราคาตัวละ 5000 ฿ รวมส่ง
ราคาแยก รวม 33500
เหมายกชุด 29900 ฿ พร้อมส่งฟรีทั่วไทย
สนใจโทร 0869455977
Digital turntable
The CDJ-800 is built around the company‘s acclaimed Jog Wheel technology. In response to feedback from the pro-DJ community, Pioneer has also added completely new and unique features:
Quick Return
Scratch the same sound repeatedly, without re-cueing every time
Auto Beat Loop
DJs can create a perfect 1/2, 1/4, 1/8 or full bar (1/1) beat loop instantly, just by touching the right button.
"Wide" Pitch Control
Create new sound effects and BPM match completely different tracks
One button touch release
Adjust Jog Wheel sensitivity to suit individual DJing styles
Digital Out
Ensure digital purity and functionality in hi-tech environments
These ground-breaking functions are packed inside a compact and durable casing that makes the CDJ-800 ideal for surviving life on the road and for playing-out in tough club environments. A world-beating combination of new and proven features, the CDJ-800 feels like a vinyl deck and delivers digital player power to home-DJs, mobile professionals and superstar DJs everywhere.
รูปสินค้าจริง
__ IntAct Battery Guard อุปกรณ์ตรวจสอบแบตเตอรี่รถ ด้วยสมาร์ทโฟน อันดับ1จากเยอรมัน
-   ตรวจสอบVoltขอแบตเตอรี่ด้วยสมาร์ทโฟนผ่านระบบบลูทูธ
-   ติดตามสถานะแบตเตอรี่ของคุณได้ตลอดเวลา
-   สามารถใช้ได้กับยานพาหนะทุกประเภท
-   ติดตั้งง่ายเพียงต่อเข้ากับแบตเตอรี่(ขั้ว+ และขั้ว-)
-   สามารถตรวจสอบแบตเตอรี่
    ขนาด 6V. 12V. และ 24V. ได้
-   ใช้พลังงานเพียง 6-24 มิลลิวัตต์
-   มีระบบป้องกันการต่อขั้วย้อนกลับ ไม่ก่อให้เกิดความเสียหาย
-   สามารถใช้งานร่วมกับ iOS, Android
    หรือ Windows 10
-   แอพพลิเคชั่นสามารถรองรับ Battery-Guard
    ได้มากถึง 10 ตัว
-   ตรวจสอบระดับการชาร์จและประวัติย้อนหลังของvoltในแบตเตอรี่ของคุณ
    ผ่านบลูทูธในสมาร์ทโฟน
อุปกรณ์เสริม ที่สามารถตรวจสอบแบตเตอรี่ได้จากโทรศัพท์มือถือ Smartphone ใด้ตลอดเวลาที่คุณต้องการ ทั้งจากมือถือระบบ ios / Android  และ windows10 ด้วยแอพฟรีจาก Intact Battery-Guard
วิธีง่ายที่สุดในการเช็คสภาพแบตเตอรี่ ใช้ในการตรวจสอบแบตเตอรี่ทั้งแบบ  6V / 12V / และ 24V ของยานพาหนะทุกชนิด
ใช้กับแบตเตอรี่ตะกั่ว-กรด ได้ทุกรุ่น รวมทั้งแบต แห้ง, น้ำ, Gel ,  Lithium และ AGM
- รับประกัน 1 ปี
- Made in Germany
- แอพพลิเคชั่นฟรีทั้งสำหรับ ios / Android  และ windows10
ราคาปกติ 2490 ฿
https://youtu.be/RKwOUHs_qy8
https://youtu.be/uXtP6hRjg7g
https://youtu.be/8uuJGEL9LSo
https://youtu.be/8X08iX1gD_U
https://youtu.be/h9gcwDQwcMQ
ราคาปกติ 2490 ฿
สนใจสินค้าโทร. 0869455977
หรือ Line ID : CTEK.THAI
ขาย D-Link DIR-816L Wireless AC750 Dual-Band Cloud Router ประกัน LT อุปกรณ์ยกกล่อง
DIR-816L AC750 Wireless DualBand Fast Ethernet Cloud Router
D-Link DIR-816L Wireless AC750 Dual-Band Cloud Router  มือสองสภาพใหม่ ประกัน LT อุปกรณ์ครบยกกล่อง 680฿ พร้อมส่ง มี1ตัว
ราคาร้อนเงินลดเหลือ 500 ems+ 50 บาท ภายใน 16/09/64
สนใจโทร 0869455977
-  D-Link DIR-816L เป็น AC Wireless Router แบบ Dual Band ความเร็วสูง
-  รองรับ Wireless b/g/n/ac ความเร็วรวมสูงสุด 750 Mbps
-  มี LAN 4 ช่องและ WAN 1 ช่อง แบบ 10/100 Mbps
-  มี USB 2.0 จำนวน 1 ช่อง สำหรับ USB Storage
-  รองรับ Mobile App ใช้งานและตั้งค่าผ่าน Smartphone mydlink Lite, mydlink SharePort
-  รองรับ Security แบบ WPA, WPA2, WPS
การเชื่อมต่อความเร็วสูง
•ใช้เทคโนโลยีไวเรสล่าสุดในการเชื่อมต่อไร้สายได้อย่างรวดเร็วด้วยระยะทางที่เพิ่มขึ้นและมีความ น่าเชื่อถือ
•เชื่อมต่อได้ถึง 750 เมกะบิตต่อวินาที
•WAN อีเธอร์เน็ตพอร์ตความเร็ว 10/100เมกะบิตต่อวินาทีสำหรับการเข้าถึงอินเทอร์เน็ตได้อย่างรวดเร็ว
• 4 อีเธอร์เน็ตLANพอร์ตความเร็ว 10/100เมกะบิตต่อวินาที ที่ให้คุณเชื่อมต่อแบบใช้สายความเร็วสูง
สะดวกกับ mydlink
•ใช้บัญชี mydlink ผ่านแอพพลิเคชันบนมือถือในการเข้าถึงไฟล์บนอินเตอร์เน็ต
•สตรีมเพลงและวิดีโอไปยังอุปกรณ์มือถือของคุณ
•อัพโหลดภาพถ่ายและวิดีโอจากอัลบั้มบนมือถือของคุณได้
แอพพลิเคชันมือถือ
•mydlink Lite ช่วยคุณเข้าถึง จัดการและดูเครือข่ายของคุณจากระยะไกลผ่านอินเทอร์เน็ต
•แอพพลิเคชัน QRS ช่วยให้คุณตั้งค่าเครือข่ายของคุณผ่านโทรศัพท์มือถือโดยไม่ต้องใช้คอมพิวเตอร์
เร้าเตอร์รุ่น DIR-816L Wireless AC750 Dual Band เป็นรุ่นที่ราคาไม่แพงแต่มีประสิทธิภาพด้วยการรวมสองเทคโนโลยีความเร็ว 802.11ac กับ           ดูอัลแบนด์ที่ปล่อยคลื่นความถี่ได้สองช่องทางเข้าด้วยกันเพื่อส่งมอบสิ่งที่ดีที่สุดให้คุณ  ระยะทางความถี่ที่ปล่อยไกลขึ้น ความเสถียรของสัญญาณ และคุณสมบัติการรักษาความปลอดภัยของข้อมูลขณะเชื่อมต่อเครือข่ายทำให้คุณเพลิดเพลินกับการใช้งานไร้กังวลจากผู้บุกรุกบนเครือข่าย
ดูอัลแบนด์ไวร์เลสเร้าท์เตอร์
ดูอัลแบนด์ไวเรสเร้าเตอร์รุ่นนี้ให้ความเร็วในการเชือมต่อสูงสุดถึง750 เมกะบิตต่อวินาทีพร้อมกับระยะทางการเชื่อมต่อที่ไกลขึ้น  โดยเทคโนโลยีดูอัลแบนด์ที่มากับเร้าเตอร์รุ่นนี้จะช่วยกระจายคลื่นความถี่ได้2ช่วง โดยช่วงแรกที่ความถี่ 2.4 กิกะเฮิร์ตช์สำหรับเล่นอินเตอร์เน็ตทั่วไป เข้าเวปไซต์ แชท หรือเล่นเกมส์ออนไลน์  ขณะที่ความถี่ 5 กิกะเฮิร์ตช์ เหมาะสำหรับสตรีมมิ่งสื่อดิจิตอลมีเดีย  นอกจากนี้ทั้งสองช่วงความถี่สามารถตั่งค่าเครือข่ายไวไฟแยกกันเพื่อให้คุณสามารถปรับแต่งเครือข่ายของคุณตามความต้องการการเชื่อมต่อของคุณ
แอพพลิเคชัน mydlink
เพียงแค่เชื่อมต่อ USB ไดรฟ์จัดเก็บข้อมูลเข้ากับเร้าเตอร์ DIR-816L  คุณก็สามารถสร้างพื้นที่เก็บข้อมูลส่วนตัวโดยสามารถเข้าถึงเอกสารของคุณ, ภาพยนตร์, ภาพและเพลงไม่ว่าคุณจะอยู่ที่ไหนผ่านแอพพลิเคชัน mydlink SharePort  ช่วยคุณประหยัดพื้นที่บนโทรศัพท์มือถือด้วยการสตรีมมิ่งการแสดงที่คุณชื่นชอบและเพลง หรือดาวน์โหลดเฉพาะเพลงไปยังอุปกรณ์ของคุณเพื่อไว้ดูขณะที่ไม่ได้เชื่อมต่ออินเตอร์เน็ต
mydlink Lite สำหรับตรวจสอบเครือข่ายของคุณทุกที่ทุกเวลา
แอพพลิเคชัน mydlink ช่วยคุณสามารถเข้าถึงและดูเครือข่ายของคุณไม่ว่าคุณจะอยู่ที่ไหน สามารถเช็คได้ว่าใครกำลังเชื่อมต่อกับเร้าเตอร์ของคุณ  โดยคุณสามารถเปลี่ยนการตั้งค่าหรือบล็อกบุคคลเหล่านั้นจากอินเทอร์เน็ตทีเชื่อมต่อกับเร้าเตอร์คุณ ผ่าน mydlink บนโทรศัพท์มือถือทั้ง  iOS หรือ Android  ผู้ปกครองสามารถตรวจสอบเว็บไซต์ที่ลูกของคุณกำลังเข้าถึง และรับทราบข้อมูลพร้อมกำหนดค่าได้ตลอดเวลาในระหว่างการเดินทาง
รีวิว D-Link DIR-816L https://digitalnext.wordpress.com/2015/09/19/review-d-link-dir-816l-wireless-ac750-dual-band-cloud-router/
ข้อมูลการรับประกันสินค้า
    การรับประกันสินค้า
    Lifetime Warranty
    บริการหลังการขาย
    D-link Call Center 02-661-7997
สนใจโทร 0869455977
« แก้ไขครั้งสุดท้าย: 15 ธันวาคม 2021, 17:36:50 โดย TM-241 » บันทึกการเข้า
TM-241
กระทู้: 4047
« ตอบ #2 เมื่อ: 26 มิถุนายน 2021, 17:23:10 »
ขาย บูสเตอร์ และ Power supply Motorola 13.8V 50Amp Base Micor repeater
รายการที่ 1
Motorola Micor Repeater power supply TPN1105A TLN5300A ex police radio network
เฉพาะ Power supply Motorola 13.8V 50Amp ถอดมาจาก Motorola MICOR Repeater (ตามรูปที่วงสีแดงๆ)
ไม่ว่า syntor , spectra , maratrac , power amplifier ขนาด 300w ก็สามารถใช้งานได้ไม่มีสัญญาณ noise หรือ hum รบกวนเครื่องวิทยุสื่อสาร
สภาพเหล็กตัวเครื่องเงาๆสวยๆ ซื้อมา หมื่นกว่า ขายราคา 7500 บาท พร้อมส่ง (นน.เยอะมากๆ)
รายการที่ 2
Motorola TLD1692D 100W Continuous Duty RF PA
เฉพาะ power amplifier ของ Base Micor repeater มาพูดง่ายๆคือบูสของ motorola base station เป็นของมือสองสภาพใหม่ๆ ( ตามรูป )
เอามาใช้งานได้ทันทีกับไฟ 13.8v ป้อน rf input 400mW - 1W ออก 100w - 125w ย่าน 144 mhz ย่าน 16 ประมาณ 70W
วัดกับ BIRD43 ไม่มีร้อน
ซื้อมาตัวละสองหมื่นกว่า ขายราคา 8500 บาท พร้อมส่ง (นน.เยอะ)
เหมาทั้งสองรายการคิด 15000 จากปกติ 16000 ประหยัดไปอีก 1000
สนใจโทร 0869455977
http://www.hamsiam.com/smf/index.php?topic=254200.0
TM-241
กระทู้: 4047
« ตอบ #3 เมื่อ: 05 กรกฎาคม 2021, 09:37:28 »
เครื่องชาร์จแบตเตอร์รี่อัจฉริยะ NOCO GENIUS10 10 A. (10000mA) ใหม่ล่าสุด!!
ปรับฟังก์ชันเพิ่มมากขึ้นด้วยการเพิ่มโหมดสำหรับชาร์จแบตเตอรี่ lithium / โปรแกรมในการชาร์จ (Can-Bus) และโหมดช่วยฟื้นฟูแบตเตอรี่จากการเกิดการเกาะตัวของผลึกซัลเฟตบริเวณแผ่นธาตุ,
โหมดอากาศหนาวเย็น และระบบการดูแลที่ช่วยถนอมและคืนสภาพให้กับแบตเตอรี่ NOCO GENIUS10 สามารถรองรับได้ทั้งแบตเตอรี่ขนาดใหญ่และขนาดเล็ สำหรับใช้แบตเตอร์รี่ 6V และ 12V
ชาร์จแบตเตอรี่ตั้งใด้สูงสุด 230แอมป์ (สามารถชาร์จรถยนต์ได้)  มีโหมดโปรแกรมที่สามารถฟื้นฟูแบตเตอรี่ เพื่ออายุการใช้งานได้
ความเร็วในการชาร์จ ชั่วโมงละ 10 แอมป์ อุปกรณ์ครบ สายแบบปากคีบและตาไก่ในตัวเดียวกัน 1 ชุด
ราคา 8900 บาท
จัดส่ง ems ฟรีทั่วประเทศ
สนใจติดต่อ 0869455977
ID Line CTEK.THAI
ตารางแสดงรายละเอียดเครื่องชาร์จแบตเตอรี่ Noco Genius G7200 / NOCO GENIUS10 สำหรับรถจักรยานยนต์ และรถยนต์ รุ่นต่าง ๆ
สินค้าที่เรามีจำหน่าย ซื้อสินค้า 1500฿ขึ้นไป ส่ง ems ฟรีทุกชิ้นครับ
เครื่อง ชาร์จ+ฟื้นฟู +จ่ายไฟ+จั๊มสตาร์ท แบตเตอรี่ แห้ง/น้ำ มอเตอร์ไซค์ รถยนต์ รถบรรทุก เรือ ยานพาหนะทุกชนิด อัจฉริยะ NOCO GENIUS จาก อเมริกา ถูกที่สุด/ดีที่สุด รับประกันสูงสุด5ปี
รถคุณไม่ค่อยใด้ขับ/จอดมากกว่าใช้งานรึปล่าว เวลาจะ ขับ/ใช้ แบตหมดใช่มั้ย ถ้าใช่ลองคลิ๊กดูครับ มีของดีสำหรับรถที่จอดมากกว่าใช้
รถคุณจอดมากกว่าขับรึปล่าว จอดนานจน แบตหมด/สตาร์ทไม่ติดใช่มั้ย ถ้าใช่สิ่งนี้ช่วยแก้ปัญหาแบตให้คุณใด้ ลองคลิ๊กดูก่อนครับ ดีแน่นอน
คลิ้กไปดูที่ลิ้งค์ข้างล่างเลยครับ สินค้ามีทุกรุ่นพร้อมส่ง ems ทั่วไทยครับ
สินค้าที่เรามีจำหน่ายนะครับ รายละเอียดทั้งหมดดูใด้ที่ http://bit.ly/1vlpE41
เครื่องชาร์จแบตเตอรี่อัจฉริยะ NOCO GENIUS จาก USA ดีที่สุด/ถูกที่สุด รับประกันสูงสุด5ปี
NOCO GENIUS รุ่น GENIUS5/GENIUS10/G15000/G26000 V.2 ใหม่ล่าสุด!!
ใช้งานง่ายชาร์จโดยไม่ต้องยกแบตเตอรี่ออกจากรถ ไม่ต้องถอดขั้วแบต เต็มแล้วตัดไฟอัตโนมัติ ไฟตกชาร์จต่อเอง รถไม่ใด้ใช้งานเสียบทิ้งใว้ใด้เป็นปีๆ
เหมาะสำหรับรถที่จอดทิ้งไว้ไม่ได้ขับ(จอดมากกว่าใช้) หมดปัญหารถสตาร์ทไม่ติด และแบตเสื่อมเร็วจากการทิ้งให้ แบตอ่อน/หรือหมดไฟ อยู่เรื่อยๆ
ใช้ได้ทั้งรถยนต์และมอเตอร์ไซค์ และยานพาหนะทุกชนิด มีระบบฟื้นฟูและกระตุ้นแบตเตอรี่ ช่วยให้แบตเต็มอยู่ตลอดเวลา ซึ่งเป็นการยืดอายุการใช้งานแบตเตอรี่ใด้ยาวนาน
NOCO GENIUS V.2 เป็นรุ่นใหม่ล่าสุด!!! ปรับฟังก์ชันเพิ่มมากขึ้นด้วยการเพิ่มโหมดสำหรับชาร์จแบตเตอรี่ lithium / โปรแกรมในการชาร์จ (Can-Bus) และโหมดช่วยฟื้นฟูแบตเตอรี่จากการเกิดการเกาะตัวของผลึกซัลเฟตบริเวณแผ่นธาตุ, โหมดอากาศหนาวเย็น และระบบการดูแลที่ช่วยถนอม กระตุ้น ฟื้นฟูแบตและคืนสภาพให้กับแบตเตอรี่
และโหมด Jump Charge ใด้ด้วย ในรุ่น G15000/G26000
สเปคเครื่องชาร์จ NOCO GENIUS จากอเมริกา รับประกันสูงสุด5ปี
- GENIUS 5  สามารถชาร์จแบต 6/12 โวลต์ ขนาดเล็กและใหญ่ ได้สูงสุดถึง120 ah ราคา 5250฿   3 year waranty
- GENIUS 10 สามารถชาร์จแบต 6/12 โวลต์ ขนาดเล็กและใหญ่ ได้สูงสุดถึง230 ah ราคา 8900฿  3 year waranty
- G15000 สามารถชาร์จแบต 12โวลต์ ได้ตั้งแต่ 30 - 400 ah / แบต 24 โวลต์ ได้ตั้งแต่ 14 - 200 ah ราคา 13,600฿   5 year waranty
- G26000 สามารถชาร์จแบต 12โวลต์ ได้ตั้งแต่ 50 - 500 ah / แบต 24 โวลต์ ได้ตั้งแต่ 25 - 250 ah ราคา 16,900฿   5 year waranty
  (G26000/G15000 มีโหมด Supply สำหรับฟื้นฟูแบตเตอรี่ที่มีแรงดันไฟฟ้าต่ำ และโหมด Jump Charge ใด้ด้วย)
- GC015 GENIUS EYELET Indicator 12V 50 cm. 750 ฿
- GC016 Dashmount Battery Indicator 12V 1.5 m. 1,250 ฿
- GC011 แจ๊คสำหรับเสียบชาร์จกับระบบ canbus สำหรับรถ BMW หรือ เสียบชาร์จกับที่จุดบุหรี่ สำหรับรถทั่วไป  950 ฿
- GC009 แจ๊ค SAE สำหรับเสียบชาร์จกับรถ HARLEY DAVIDSON หรือ รถอื่นๆที่ใช้แจ๊ค SAE  590 ฿
เครื่องทดสอบและวิเคราะห์สภาพแบตเตอรี่แบบดิจิตอล DHC BT111/BT222 มีคู่มือไทย
- DHC BT111 Battery Analyzer เครื่องตรวจสอบและวิเคราะห์สภาพแบตเตอรี่ 2950฿ 1 year warranty
- DHC BT222 Battery Analyzer 3in1 เครื่องวิเคราะห์สภาพแบตเตอรี่ 12V / ทดสอบ ระบบการชาร์จ (ไดร์ชาร์จ) / วิเคราะห์ระบบขณะสตาร์ท (ไดร์สตาร์ท) ใด้ด้วย 3in1  3750฿ 1 year warranty
รีวิวการใช้งาน วีดีโอสาธิตการทำงาน BT222 https://www.youtube.com/watch?v=J5xLVwua0X8
https://www.youtube.com/watch?v=6glRNWsZ9nM
- Intact Battery-Guard - Smart Battery Health Monitor อุปกรณ์สำหรับตรวจสอบแบตเตอรี่ได้จากโทรศัพท์มือถือ
อุปกรณ์เสริม ที่สามารถตรวจสอบแบตเตอรี่ได้จากโทรศัพท์มือถือ Smartphone ใด้ตลอดเวลาที่คุณต้องการ ตรวจสอบแบตเตอรี่ทั้งแบบ  6V / 12V / และ 24V ของยานพาหนะทุกชนิด
ลดราคาพิเศษเหลือเพียง 1,950 บาท พร้อมส่ง ems ฟรีทั่วไทย
ซื้อสินค้า 1500฿ ขึ้นไปพร้อมส่ง ems ฟรีทั่วไทย
- สนใจรุ่นใหนโทร 0869455977
หรือ Line ID : CTEK.THAI หรือ NOCOTHAI
หรือคลิ๊ก http://line.me/ti/p/~CTEK.THAI
รายละเอียดเครื่องชาร์จ/จั๊มพ์สตาร์ททั้งหมดดูใด้ที่ http://bit.ly/1vlpE41
- NOCO GENIUS GENIUS 5 เหมาะที่สุดกับการชาร์จแบตมอเตอร์ไซค์ และชาร์จ BigBike SuperBike ใช้ชาร์จแบตรถยนต์ใด้ แต่ชาร์จแบตรถยนต์ค่อนข้างช้า ถ้าไม่ซีเรียสเรื่องเวลา และแบตรถยนต์ไม่เกิน 120 แอมป์ GENIUS 5 ก็ใช้ใด้ครับ
- NOCO GENIUS GENIUS 10 เหมาะที่สุดกับการชาร์จแบตมอเตอร์ไซค์ และชาร์จ BigBike SuperBike และแบตรถยนต์ ขนาดไม่เกิน 230 แอมป์ ชาร์จแบตใด้เร็วกว่ารุ่น GENIUS 5 1เท่า
- NOCO Genius G26000 ดีที่สุด 26A (26000mA) Pro-Series UltraSafe Smart Battery Charger with JumpCharge
สำหรับชาร์จแบตเตอรี่ 12V และ 24V เครื่องชาร์จสำหรับใช้งานกับแบตเตอรี่ขนาดใหญ่ ตั้งแต่ 25 แอมป์ขึ้นไป - 500Ah เช่น รถยนต์, เรือ, รถบรรทุก, รถ RV และรถแทรกเตอร์
G26000 ชาร์จแบตใด้เร็วกว่ารุ่น GENIUS 5 6เท่า เช่นถ้ารุ่น G5 ชารจเต็มที่6ชม รุ่นG26000 ก็จะชารจเต็มที่ 1 ชม.
มาพร้อมฟังก์ชันการทำงานพิเศษสำหรับรักษาแบตเตอรี่จากภาวะการเกิดผลึกซัลเฟต, โหมด Supply สำหรับฟื้นฟูแบตเตอรี่ที่มีแรงดันไฟฟ้าต่ำ และโหมด Jump Charge ใด้ด้วย
ถ้าคุณเลือก เครื่องชาร์จ / เครื่องจั๊มพ์สตาร์ท ไม่ถูก เรามีคำแนะนำในการเลือกเครื่องชาร์จให้ตรงกับความต้องการ จากฟังค์ชั่นการใช้งาน และความเร็วในการชาร์จ ลองอ่านดูครับ
- ถ้าไม่เกี่ยงเรื่องงบและต้องการ ชาร์จทั้งแบตเตอรี่ 12V และ 24V แนะนำรุ่นใหญ่สุด noco G26000 ครับ สะดวกสุด ชาร์จเร็วสุดเร็วกว่ารุ่นเล็กสุด8เท่า  จั๊มสตารทใด้ภายใน5นาที 16900฿
- ถ้าต้องการให้ถูกกว่านั้น อาจใช้เครื่องชาร์จ noco G15000 ชาร์จใด้ทั้งแบตเตอรี่ 12V และ 24V ชาร์จเร็วกว่ารุ่นเล็กสุด4เท่า จั๊มสตารทใด้ภายใน5นาที 13600฿
- หรือถ้าไม่ต้องการ จั๊มสตาร์ท และชาร์จไม่ช้ามากก็ใช้ noco GENIUS 10 เร็วกว่ารุ่นเล็กสุด1เท่า 8900฿
- ถ้าไม่ต้องการฟังค์ชั่น จั๊มสตาร์ทและโหมดจ่ายไฟ  และไม่ซีเรียสความช้าในการชาร์จรถยนต์ก็ตัวเล็กสุด noco GENIUS 5  5250฿
*** สนใจรุ่นใหนโอนแล้วแจ้งใด้เลยครับ สินค้าพร้อมส่ง ems ทั่วไทยครับ ***
« แก้ไขครั้งสุดท้าย: 12 กรกฎาคม 2021, 09:13:20 โดย TM-241 » บันทึกการเข้า
TM-241
กระทู้: 4047
« ตอบ #4 เมื่อ: 07 กรกฎาคม 2021, 11:50:54 »
ดีมากกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกกก
TM-241
กระทู้: 4047
« ตอบ #5 เมื่อ: 12 กรกฎาคม 2021, 09:13:37 »
TM-241
กระทู้: 4047
« ตอบ #6 เมื่อ: 17 กรกฎาคม 2021, 08:20:04 »
ถูกกกกกกกกกกกกกกกกกมากกกกกกกกกกกกกกกกกกก
TM-241
กระทู้: 4047
« ตอบ #7 เมื่อ: 22 กรกฎาคม 2021, 11:29:58 »
ถูกที่สุดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดดด
TM-241
กระทู้: 4047
« ตอบ #8 เมื่อ: 26 กรกฎาคม 2021, 09:52:00 »
TM-241
กระทู้: 4047
« ตอบ #9 เมื่อ: 30 กรกฎาคม 2021, 09:01:55 »
ุถูกที่สุดด
หน้า: [1] 2 3 ... 5
