23 พฤศจิกายน 2024, 14:12:56 *
ผู้เขียน หัวข้อ: __ ขาย FiberHome AN5506-04-FA GPON ONU Fiber Optic AC1200 (650฿)  (อ่าน 7930 ครั้ง)
TM-241
กระทู้: 4045
« ตอบ #10 เมื่อ: 20 มิถุนายน 2021, 16:44:01 »
__ เป็น ดีเจรถซิ่ง ง่ายๆด้วย มือถือ/ipad + สาย Griffin DJ Cable สำหรับแอพ DJay
สาย Griffin DJ Cable for iphone ipad ipod สำหรับแยกเสียงหูฟังกับลำโพง ในการใช้แอพ djay
https://griffin.zendesk.com/hc/en-us/article_attachments/203497324/P4971_DJcable_ts.pdf
The Griffin Technology DJ Cable is designed to be used with iOS mobile devices and enables the Split Output function when using the djay algoriddim app. With Split Output mode enabled, djay sends the master output to the left channel, and the cue output to the right channel. This lets you cue songs through your headphones independently of the mix that's going through the speakers. The cable has connectors for the speaker system, headphones and audio jack for your device.
For iOS mobile devices - enables Split Output when using djay app
Splitter cable allows you to hear the speaker mix and the song being cued up
Connectors for speaker system, headphones and audio jack on your iOS device
Pre-Cueing
Previewing with headphones
The ability to pre-cue, or preview, the next track through your headphones is essential for any DJ to seamlessly mix the currently playing track into the next track. This allows for finding the perfect next track, flawless beatmatching, and creating a mix customized for your crowd.
In djay, there are two ways you can pre-cue your tracks: by using the Split Output function paired with a stereo/mono DJ split cable, or by connecting an external sound card or DJ controller.
A proper DJ split cable lets you cue up the next track in your headphones independently from what the crowd is currently hearing from the speakers, allowing for a smooth mix.
DJ split cables can be enabled through djay’s Split Output function for pre-cueing. Optimal features you want to look for are gold-plated connectors for improved conductivity and better signal, as well as a durable exterior for longevity.
Note: A DJ split cable splits your stereo jack into two mono channels. This means your speaker output using this setup will always be mono (using two duplicate mono output channels).
รายละเอียดสินค้า
อุปกรณ์เสริมสำหรับ ipad, iphone, ipod touch เพื่อใช้เชื่อมกับโปรแกรม DJ สามารถแยกเสียงหูฟังกับลำโพงได้ ของมือ1 เก่าเก็บ
950 ฿ รวมส่ง ems/kerry
สนใจโทร 0869455977
หรือ Line ID: ctek.thai
http://www.hamsiam.com/smf/index.php?topic=254318.0
ขาย ซาวด์การ์ด แยก8ไลน์ Creative Sound Blaster Audigy 2 ZS รหัส M แจ็คทอง สินค้าใหม่
การ์ด+ไดร์เวอร์+Midi Port
เป็นตัวเต็ม คือตัวที่ลง ไดร์เวอร์ได้ครบ และใช้ได้ครบทุกฟังชั่น
และให้สังเกตุที่ S/N ด้วยนะครับ มีขึ้นต้นด้วยรหัส M และ R
รหัส M เป็นตัวเต็ม Retail ที่ Creative ขายอย่างเป็นทางการ
รหัส R เป็นตัวเต็ม ที่อาจได้รับการซ่อม หรือ มีตำหนิ หรือ ผ่านการ QC 2 ครั้ง หรือผ่านการ Re-work หรืออื่นๆ
ที่แตกต่างระหว่างตัวเต็มกับตัวไม่เต็มก็คือ ตัวเต็มจะเล่นออฟชั่นทุกอย่างได้หมดครับ
ส่วนตัวไม่เต็ม (OEM ของDELL)เขาจะตัดออฟชั่นบางอย่างออกไป และจะมีปัญหาเรื่องไดร์เวอร์มาก
วิธีสังเกตุก็คือ ตัวเต็มถ้าเรามองเข้าไปที่ตัวอุปกรณ์ ที่เสียบสายต่างๆๆจะเป็นสีดำหมด ส่วนตัวไม่เต็ม ที่เสียบสายต่างๆๆจะมีสีเขียวอยู่
ขาย ซาวด์การ์ด  Creative Sound Blaster Audigy 2 ZS (แจ็คทอง)
เล่น SoundFont ได้   แยกไลน์ได้ 8 ไลน์
เล่น AC3 , DTS ดูหนังฟังเพลงสุดยอด
ซาวด์การ์ดในตำนานที่ว่ากันว่า เสียงดีที่สุดสำหรับซาวด์การ์ดยุคสล๊อต PCI เสียงที่ไม่มีใครทำได้เหมือนตลอดกาล ความใสสะอาดอย่างกับแก้ว ความนุ่มละมุล ความชัดเจนทุกๆย่านเสียง
สินค้าใหม่ การ์ด+ไดร์เวอร์+Midi Port 1950 บาท พร้อมส่ง
spec
Sound Blaster Audigy2 ZS 7.1 [ SB0350 ]
Spec - PCI , 7.1 ch , microphone , line-in , FireWire , Digital I/O ( for SPDIF I/O Module )
- 24-bit Analog-to-Digital conversion of analog inputs 96kHz sampling rate and Up to 192kHz in stereo
- 24-bit Digital-to-Analog conversion of digital sources Up to 96kHz sampling rate
- SPDIF (Sony/Philips Digital Interface) input at up to 24-bit/ 96kHz quality
- SPDIF output up to 24-bit at 48 or 96kHz
- Signal-to-Noise Ratio 106dB to 108dB
- SB1394/FireWire allows super-fast transfer of files to devices or PCs
- ASIO 2.0 drivers for low latency (as low as 2ms) multi-track playback and recording at 16-bit/48kHz or 24-bit/96kHz
- DTS ,DTS-ES ,Dolby Digital EX , THX, DirectSound ,ASIO 2 ,EAX 4.0 ,EAX Advanced HD ,EAX 64 3D
จุดเด่น - ให้แนวเสียงกลางอิ่ม สดใส เบสกระชับ เวทีโปร่ง มีมิติ เหมาะทั้งการใช้ในด้านฟังเพลงและด้านงานดนตรี
ข้อคิดเห็น - ใช้ EMU 10k2.5 เช่นเดียวกับ Audigy4 , ADCเป็น Philips UDA1361Tchip และ DAC CS4382
Opa คู่หน้า JRC4556a อีก 3 ตัว surround ใช้ ST4558c ,ในรุ่นแจ็คสีโดนตัด DD/DTS ในตัวออกไป
สำหรับตัว Platinum นั้น จะขายมาพร้อม Front-Panel เพื่อใช้คุณสมบัติในด้านการเชื่อม
ต่อพอร์ตต่างๆ สำหรับงานตัดต่อ/บันทึกเสียง
สนใจโทร 0869455977
https://www.overclockzone.com/forums/forum/marketplace/it-market/sound-card/17104852-___-%E0%B8%82%E0%B8%B2%E0%B8%A2-%E0%B8%8B%E0%B8%B2%E0%B8%A7%E0%B8%94%E0%B9%8C%E0%B8%81%E0%B8%B2%E0%B8%A3%E0%B9%8C%E0%B8%94-%E0%B9%81%E0%B8%A2%E0%B8%818%E0%B9%84%E0%B8%A5%E0%B8%99%E0%B9%8C-sound-blaster-audigy-2-zs-%E0%B8%A3%E0%B8%AB%E0%B8%B1%E0%B8%AA-m-%E0%B9%81%E0%B8%88%E0%B9%87%E0%B8%84%E0%B8%97%E0%B8%AD%E0%B8%87-%E0%B8%AA%E0%B8%B4%E0%B8%99%E0%B8%84%E0%B9%89%E0%B8%B2%E0%B9%83%E0%B8%AB%E0%B8%A1%E0%B9%88
**หมายเหตุ**
