23 พฤศจิกายน 2024, 18:09:32 *
ผู้เขียน หัวข้อ: ขาย * Reddot 5011 Sw-M2400 2.4G, WLAN, WiFi Digital Swr Meter N-Female Connector  (อ่าน 1852 ครั้ง)
E28BU
กระทู้: 2330
« เมื่อ: 08 มีนาคม 2021, 20:18:15 »
The main technical parameters:
1, the maximum power: 33dbm
2, frequency: 2.3 ~ 2.5GHZ (WiFi)
3, orientation: 20db
4, insertion loss: <1.5db
5, VSWR range: 1.00 to 19.9
6, power range: 0.0dbm ~ 33dbm
7, showing power: +0.00 ~ +33 dbm
8, power consumption: AAA * 3 (7 #), <10mA
พารามิเตอร์ทางเทคนิคหลัก:
1 กำลังไฟสูงสุด: 33dbm
2 ความถี่: 2.3 ~ 2.5GHZ (WiFi)
3, การวางแนว: 20db
4, การสูญเสียการแทรก: <1.5db
5, VSWR range: 1.00 ถึง 19.9
6, ช่วงพลังงาน: 0.0dbm ~ 33dbm
7 แสดงอำนาจ: +0.00 ~ +33 dbm
8, การใช้พลังงาน: AAA * 3 (7 #), <10mA
Use manual:
1: Teased out four M3 screws on the back cover, deposit three alcaline AAA(7#) batteries in the battery box and close the cover.
2: Transmitting equipment is connect to the "TX" side, antenna is connect to the "ANT" side.
3: The SWR METER is opened by press the red button, it will begin to test after the LED shows "+1.8.8P" about 2 sends.
4: The standing wave and power are turned on the LCD in 2 second intervals. It will stop take turns after press the red button, and begin to turn by press the red button again.
5: The red button has many functions. When keep press the button over the 0.5 send, the LCD backlight can on or off. The SWR METER will be turned off after keep press the button over the 2 send.
6: Three states of the LCD show
I: Standing-Wave Ratio is dimensionless ratio, we called SWR for short. If the LCD shows"1.45r", it means the present SWR is 1.45. "1. _. _r" means standing-wave greater than 19.9 or no signal.
II: Average power. For example "+17.5P" means average power is 17.5dbm. If the LCD shows "+1. _. _P", it means the power is too large to measure. If the LCD shows "-1. _. _", it means the power it too small to measure(<0dBm).
III: Instantaneous peak value For example if the LCD shows "+28", it means the max. Transmitting power is 28dbm. If the LCD shows "+1. _. _" it means the power is too large to measure. If the LCD shows "-1. _. _", it means the power it too small to measure(<0dBm).
1: คลายสกรู M3 สี่ตัวที่ฝาหลังใส่แบตเตอรี่อัลคาไลน์ AAA (7 #) สามก้อนไว้ในกล่องแบตเตอรี่แล้วปิดฝา
2: อุปกรณ์ส่งเชื่อมต่อกับด้าน "TX" เสาอากาศเชื่อมต่อกับด้าน "ANT"
3: SWR METER เปิดโดยกดปุ่มสีแดงจะเริ่มทดสอบหลังจาก LED แสดง "+ 1.8.8P" ประมาณ 2 ครั้ง
4: คลื่นนิ่งและพลังงานจะเปิดบน LCD ในช่วงเวลา 2 วินาที จะหยุดผลัดกันหลังจากกดปุ่มสีแดงและเริ่มหมุนโดยกดปุ่มสีแดงอีกครั้ง
5: ปุ่มสีแดงมีฟังก์ชันมากมาย เมื่อกดปุ่มค้างไว้เหนือ 0.5 ส่งไฟพื้นหลัง LCD จะเปิดหรือปิดได้ SWR METER จะถูกปิดหลังจากกดปุ่มค้างไว้เหนือการส่ง 2 ครั้ง
6: สามสถานะของการแสดง LCD
I: Standing-Wave Ratio คืออัตราส่วนไร้มิติเราเรียกสั้น ๆ ว่า SWR หาก LCD แสดง "1.45r" หมายความว่า SWR ปัจจุบันคือ 1.45 "1. _. _r" หมายถึงคลื่นนิ่งที่มากกว่า 19.9 หรือไม่มีสัญญาณ
II: กำลังเฉลี่ย ตัวอย่างเช่น "+ 17.5P" หมายถึงกำลังเฉลี่ยคือ 17.5dbm หากหน้าจอ LCD แสดง "+1. _. _P" แสดงว่ากำลังไฟฟ้ามีขนาดใหญ่เกินกว่าที่จะวัดได้ หากจอ LCD แสดง "-1. _. _" แสดงว่ากำลังไฟฟ้าที่น้อยเกินไปที่จะวัดได้ (<0dBm)
III: ค่าสูงสุดทันทีตัวอย่างเช่นถ้า LCD แสดง "+28" ก็หมายถึงค่าสูงสุด กำลังส่ง 28dbm หากหน้าจอ LCD แสดง "+1. _. _" แสดงว่ากำลังไฟฟ้ามีขนาดใหญ่เกินไปที่จะวัดได้ หากจอ LCD แสดง "-1. _. _" แสดงว่ากำลังไฟฟ้าที่น้อยเกินไปที่จะวัดได้ (<0dBm)
ใช้งานได้ปกติ upgrade diode เป็น HSMS-286x Series แล้ว ทำให้ความไวในการวัดค่า ดีมากยิ่งขึ้น และตอบสนองความถี่ได้กว้างขึ้น
(ตำหนิรอยแตกมุมขวาบน ไม่มีผลต่อการวัดทดสอบหรือแสดงผล)
ขาย 1,250 บาท รวมค่าจัดส่ง EMS ครับผม ...
« แก้ไขครั้งสุดท้าย: 15 มีนาคม 2021, 07:16:25 โดย E28BU » บันทึกการเข้า
Mobile Phone : 0933148548
E-Mail : curvetracermania(แอท)gmail.com
Facebook ชื่อ KOMBAT WIFI HOTSPOT
ID Line ::  kombatshop
ธนาคารกรุงไทย ออมทรัพย์ สาขาแพร่ 5061565681 ชื่อ เกษตรพงษ์  ตันพรม
E28BU
กระทู้: 2330
« ตอบ #1 เมื่อ: 09 มีนาคม 2021, 13:19:09 »
E28BU
กระทู้: 2330
« ตอบ #2 เมื่อ: 27 มีนาคม 2021, 12:41:59 »
E28BU
กระทู้: 2330
« ตอบ #3 เมื่อ: 15 เมษายน 2021, 20:21:17 »
E28BU
กระทู้: 2330
« ตอบ #4 เมื่อ: 02 พฤษภาคม 2021, 12:59:21 »
E28BU
กระทู้: 2330
« ตอบ #5 เมื่อ: 24 พฤษภาคม 2021, 10:27:39 »
