26 พฤศจิกายน 2024, 07:26:40 *
ผู้เขียน หัวข้อ: HF(CB)-VHF-UHF ANTENNA MITTER 2015  (อ่าน 1056 ครั้ง)
indexone
กระทู้: 491
ทำมัยเรื่องง่ายๆกับทำให้มันอยาก กับ เรื่องอยากๆกับอยากขึ้นไปอีก
« เมื่อ: 05 พฤศจิกายน 2016, 14:02:35 »
CAA-500MARKII
The NEW CAA-500MARKII SWR/Impedance Analyzer is finally arriving from the Comet factory!
The new analyzer retains the same analog cross needles to display SWR and impedance, but ADDS a full color TFT LCD display screen providing graphic and numerical SWR along with total impedance with R and X values.
Features:
AUTO SWEEP MODE
Automatically graphs the SWR on the LCD display.   Choose any one of the pre-set amateur band frequency ranges and press the sweep button…in about 30 seconds the SWR graph is completed and displayed.
MANUAL SWEEP MODE
Choose the band and manually set the band-width and manually sweep the chosen frequency range.
MULTIPLE MANUAL SWEEPS
Should you want to make an adjustment to the antenna length, to the position, height above ground, a gamma match adjustment,
etc…you can overlay 5 manual sweep results in different colors!  Instantly graph and see exactly what happened after each adjustment!
Range: 1.8 – 500MHz (including 222MHz band)
RF output level:  0dBm 1 mW
Measured SWR Range:  Analog meter 1.0 – 6.0:1 , LCD display 1.0 – 9.9:1
Impedance measurements: 12.5-300 ohms
Reactance range:  0 – 500 Ohms (absolute value) 1.8 -190MHz
Battery indicator and selectable Auto-Power-Off timer
Operates up to 9 hours continuous using six AA Alkaline or NiMH cells (not included) or use an external 8-16VDC 200ma power source (DC cable included)
Internal trickle charger option when using NiMH batteries
Size: 3.5 x 7.75 x 2.65 inches (overall)
Weight: 2lbs 2oz with alkaline batteries installed
Available from all major Ham Radio Dealers in the US.
The CAA-500MarkII is the primary tool for any antenna adjustment or diagnostic project.
วีโอแนะนำสินค้า
https://www.youtube.com/watch?v=vQU1UcDyuWQ
ราคา 21,000 บาท พร้อมส่ง
สนใจติดต่อ ทาง IB หรือโทรสอบถาม 095-657-4555  HS4YQT
indexone
กระทู้: 491
« ตอบ #1 เมื่อ: 06 พฤศจิกายน 2016, 12:57:44 »
indexone
กระทู้: 491
« ตอบ #2 เมื่อ: 07 พฤศจิกายน 2016, 23:17:29 »
indexone
กระทู้: 491
« ตอบ #3 เมื่อ: 10 พฤศจิกายน 2016, 22:59:58 »
indexone
กระทู้: 491
« ตอบ #4 เมื่อ: 14 พฤศจิกายน 2016, 03:36:10 »
indexone
กระทู้: 491
« ตอบ #5 เมื่อ: 26 พฤศจิกายน 2016, 21:30:52 »
indexone
กระทู้: 491
« ตอบ #6 เมื่อ: 19 กุมภาพันธ์ 2017, 14:45:35 »
indexone
กระทู้: 491
« ตอบ #7 เมื่อ: 19 มิถุนายน 2017, 18:47:47 »
สนใจโทร หรือ ไลท์ 0956574555  ขอบคุณครับ
indexone
กระทู้: 491
« ตอบ #8 เมื่อ: 29 มิถุนายน 2017, 15:14:57 »
