25 พฤศจิกายน 2024, 11:24:36 *
ผู้เขียน หัวข้อ: จำหน่าย ICOM IC-7410 HF+50MHz ราคา 75,000.- ลดเหลือ 58,000.-  (อ่าน 3294 ครั้ง)
tenmetershop
กระทู้: 1425
« เมื่อ: 20 ตุลาคม 2015, 12:34:59 »
ติดต่อ 081-5580422 K.มนตรี
The IC-7410 replaces the late IC-746PRO with upgrades to performance and specifications that provide excellent cost performance. This specialized HF rig employs the same high grade DSP unit and double conversion super-heterodyne system developed from the latest technology used in the IC-7800/IC-7700/ IC-7600 series. In addition, when used with the optional FL-430 and FL-431 filters, narrow mode signals are protected from adjacent inband signals. The 3kHz first IF filter is especially effective in the CW and SSB modes.
The Icom IC-7410 provides professional performance in the 160 to 6 meter amateur bands. It utilizes Icom's proven IF-DSP technology as this unit is reported to have a 15kHz roofing filter in the stock unit with an optional 6 and 3 kHz filters to be available post it’s official release. The IC-7410 features a sharp black and white LCD slightly larger than that of it’s predecessor the IC-746 Pro.
The IC-7410 has a superior general coverage receiver covering 30 kHz to 60 MHz with a +30dbm 3rd order receive intercept point and superior  ±0.5 p.p.m. frequency stability.
Much like the IC-746PRO, the IC-7410 supports a bandscope function, and RTTY decode capability. Other specifications include a ±9.999kHz RIT, Band Pass Filter, a Quick Split function and a band edge beep. Like it’s predecessor this transceiver has a built in tuner and will produce an output of 100 watts on all HF Bands and 6 Meters.  The IC-7410 has both CI-V and USB ports on the rear of the unit. This radio requires an external 13.8 VDC at 23 amps.
Feature and Specifications:
    ► +30dBm 3rd order intercept point in HF bands
    ► Double conversion super-heterodyne system improves inband IMD characteristics
    ► 32-bit floating point DSP unit
    ► Optional 3kHz and 6kHz first IF filters
    ► Large LCD display
    ► ±0.5ppm frequency stability
    ► Built-in simple band scope
    ► Built-in automatic antenna tuner
    ► Optional RS-BA1 for IP remote control
    ► Built-in voice synthesizer announces operating frequency, mode and S-meter level
    ► Ample CW functions
    ► Microphone equalizer and adjustable transmit bandwidth
« แก้ไขครั้งสุดท้าย: 21 มิถุนายน 2017, 12:20:58 โดย tenmetershop » บันทึกการเข้า
จำหน่ายวิทยุสื่อสารและอุปกรณ์
www.tenmetershop.com
HS5FYK
กระทู้: 1804
« ตอบ #1 เมื่อ: 20 ตุลาคม 2015, 12:48:47 »
ปักหมุดไว้ก่อน
My Polar Bear...
tenmetershop
กระทู้: 1425
« ตอบ #2 เมื่อ: 14 กรกฎาคม 2016, 16:18:21 »
http://www.tenmetershop.com/
tenmetershop
กระทู้: 1425
« ตอบ #3 เมื่อ: 13 มีนาคม 2017, 11:40:15 »
tenmetershop
กระทู้: 1425
« ตอบ #4 เมื่อ: 21 มิถุนายน 2017, 12:21:11 »
tenmetershop
กระทู้: 1425
« ตอบ #5 เมื่อ: 28 กรกฎาคม 2017, 15:57:28 »
tenmetershop
กระทู้: 1425
« ตอบ #6 เมื่อ: 02 มิถุนายน 2018, 11:44:59 »
