27 พฤศจิกายน 2024, 01:49:52 *
หน้า: [1] 2 3 ... 30
ผู้เขียน หัวข้อ: TYT,TH-9800วิทยุสื่อสารโมบาย,แยกหน้าได้  (อ่าน 41947 ครั้ง)
nawin
member.
กระทู้: 64544
« เมื่อ: 16 ธันวาคม 2014, 22:38:18 »
โทร.083-3060449
วิทยุสื่อสารโมบายTYT TH-9800 แยกหน้าได้
TYT Model  TH-9800
Frequency range
Left Band:         RX:26-33 47-54 108-180 350-399.995 400-512 750-950MHz
                       TX:26-33 47-54 134-174 400-480MHz
Right Brand        RX:134-180 400-512MHz
                        TX:134-174 400-480MHz
Quad band Transmitter and receiver           29/50/144/430MHz
Channel steps                       2.5/5/6.25/7.5/8.33/10/12.5/15/25/30/50kHz
Modes of emission                 FM
Antenna impedance                 50 ohm Unbalanced(antenna duplexer built-in)
Frequency stability                  ±5ppm
Operating temperature range     -20°C—60°C
Supply voltage             13.8V DC
Current consumption      RX:0.5A TX:8.5A
Case size(W x H x D)     140 x 41.5 x 168mm
Weight       About 1.2kg
ราคา 8,700  บาท
Main features
Cover 29/50/144/430MHz four transmitting bands       Yes
Wide receiving range:26-33 47-54 108-180 320-512 750-950MHz   Yes
AM Air-band reception capability       Yes
Independent controls for each left and right band        Yes
V+U,U+U,V+U simultaneous receive capability                         Yes
Built-in V+U cross band repeater and full duplex capability         Yes
800memory channels and independent setting per channel          Yes
50W of high power output for VHF band and 40W for UHF band    Yes
Standard 50 groups of CTCSS tone and 104 groups of DCS code    Yes
User-defined CTCSS tone and DCS code capability                Yes
DTMF/2-tone/5-tone for selective calling       Yes
Encryption scramble(8 group)              Yes
Automatic repeater SHFT(ARS)             Yes
Detachable front controller and remote mounting capability    Yes
Ultra-size LCD dual display screen        Yes
User-programmable microphone keys    Yes
Adjusting the squelch level          Yes
Selecting the operating band        Yes
Memory scanning VFO scanning    Yes
Cross-band repeater operation     Yes
Specifications
Output power                           50/20/10/5W (29/50/144MHz)
                                             40/20/10/5W (430MHz)
Maximum deviation                   ±5kHz
Spurious radiation                    <-60dB(29MHz:<-50dB)
Modulation distortion                <3%
Microphone impedance               2k ohm
Receiver
Intermediate frequency              49.95mhZ/450khZ(Left band)
                                              38.85MHz/450MHz (Right band)
Sensitivity(for 12dB SINAD)         <0.2µV
Squelch sensitivity                     <0.16µV
Selectivity                                12kHz/30kHz
Features
Four transmit bands:  29 / 50 / 144 / 430 MHz
Wide receive range:   26-33 / 47-54 / 108-180 / 320-512 / 750-950 MHz
AM Aircraft-band receive capability (108-118 MHz)
Independent controls for left and right sides
V+V, U+U, U+V or V+U simultaneous receive capability
Cross-band repeater and Full Duplex capability
800 memory channels with independant settings for each
6 Hyper Memory channels
Wide Band (25 kHz)  /  Narrow Band (12.5 kHz)
Tuning Steps: 2.5/5/6.25/7.5/8.33/10/12.5/15/25/30/50/100 KHz
Output: 50 watts VHF / 40 watts UHF
DTMF / 2-Tone / 5-Tone capability
50 groups CTCSS / 104 groups DCS
Scrambler and Compactor functions
Automatic repeater shift
Multi-function programmable microphone
Detachable front head with remote mounting capability
Current draw (min/max):  RX = 0.5 A  and  TX = 8.5 A  (แอท) 13.8 VDC
Size (W/D/H):  5-1/2 x 6-5/8 x 1-5/8 inches
Weight: 2.6 lbs.
Comes with Head Separation Cable
เลขบัญชี        หน้าหลักรวมสินค้า        FaceBook        ตรวจสอบพัสดุEMS
เบอร์หลักโทร. 083-3060449 ระบบ Line เมมเบอร์นี้ไว้เลยครับ
Line ID: nawin2011_01
อีกเบอร์สำรองโทร.062-5190117, 082-9858126
« แก้ไขครั้งสุดท้าย: 19 กุมภาพันธ์ 2019, 13:59:32 โดย nawin » บันทึกการเข้า
โทร.0833060449
nawin
member.
กระทู้: 64544
« ตอบ #1 เมื่อ: 17 ธันวาคม 2014, 21:51:25 »
รอบส่งวันนี้ 17.112.57
ทางร้านดำเนินส่งสินค้าให้แล้วนะครับ
หมายเลขพัสดุทางร้านส่งข้อความแจ้งครบทุกท่านแล้วนะครับ
ท่านที่ไม่มีข้อความเข้าติดต่อมาได้ครับ
ขอขอบคุณทุกท่านครับ
https://www.facebook.com/Ce.Radio.2011
CE-Radio QC Team.........ยินดีรับใช้ครับ
nawin
member.
กระทู้: 64544
« ตอบ #2 เมื่อ: 18 ธันวาคม 2014, 13:29:26 »
เปิดร้านจ้า ยิงฟันยิ้ม ยิงฟันยิ้ม
nawin
member.
กระทู้: 64544
« ตอบ #3 เมื่อ: 19 ธันวาคม 2014, 10:27:36 »
ขาย วิทยุสื่อสาร อุปกรณ์ เสามือถือ เสาติดรถ เสาติดบ้าน แบตเตอรี่ คลิบหลัง แท่นชาร์จ สายนำสัญญาณ ขั่วแปลง
รับดำเนินการขอใบอนุญาติ มี/ใช้, ค้า, ตั้งเสาบ้าน,เสารถ,
nawin
member.
กระทู้: 64544
« ตอบ #4 เมื่อ: 19 ธันวาคม 2014, 15:51:02 »
nawin
member.
กระทู้: 64544
« ตอบ #5 เมื่อ: 20 ธันวาคม 2014, 13:17:41 »
nawin
member.
กระทู้: 64544
« ตอบ #6 เมื่อ: 21 ธันวาคม 2014, 15:16:07 »
nawin
member.
กระทู้: 64544
« ตอบ #7 เมื่อ: 22 ธันวาคม 2014, 10:29:55 »
nawin
member.
กระทู้: 64544
« ตอบ #8 เมื่อ: 23 ธันวาคม 2014, 08:36:57 »
nawin
member.
กระทู้: 64544
« ตอบ #9 เมื่อ: 23 ธันวาคม 2014, 14:49:05 »
