18 พฤศจิกายน 2024, 09:21:27 *
ผู้เขียน หัวข้อ: เปิดรับ Order MFJ 259B HF/VHF SWR Analyzers  (อ่าน 566 ครั้ง)
banhdit
กระทู้: 245
« เมื่อ: 03 มิถุนายน 2014, 11:21:33 »
เปิดรับ Order MFJ 259B HF/VHF SWR Analyzers สำหรับท่านที่สนใจ
Brand:MFJ
Manufacturer's Part Number:MFJ-259B
Part Type:Antenna Analyzers
Product Line:MFJ 259B HF/VHF SWR Analyzers
DXE Part Number:MFJ-259B
Antenna Analyzer Frequency Range:1.8-170 MHz
RF Connector Type:UHF female, SO-239
Band Selection Control:Rotary switch
Frequency Control Style:Dial
Lockable Tuning Dial:No
Internal Battery Operation:Yes
Batteries Included:No
External Power Input Voltage:12 Vdc
Analyzer Width:4.000 in.
Analyzer Height:6.750 in.
Analyzer Depth:2.000 in.
Quantity:Sold individually.
MFJ 259B HF/VHF SWR analyzers are compact, battery-powered RF impedance analyzers. They combine four basic circuits; a 1.8-170 MHz variable frequency oscillator, a frequency counter, a 50 ohm RF bridge, and an 8-bit micro-controller. The analyzers make a wide variety of useful antenna or impedance measurements, including coaxial cable loss and distance to an open or short. Primarily designed for analyzing 50 ohm antenna and transmission line systems, the MFJ 259B HF/VHF SWR analyzers also measure RF impedances between a few ohms and several hundred ohms. They also function as a signal source and frequency counter. The frequency range of impedance measurement is 1.8 to 170 MHz, in six overlapping bands. The accuracy of the analyzers is enhanced by the use of special microwave zero-bias Schottky detectors with matching compensating diodes. They are compensated to provide the best possible linearity with both high and low impedance loads, making the A/D converter's 1/2 percent resolution the primary limitation.
Can be used to test:
*Antennas: SWR, impedance, reactance, resistance, resonant frequency, and bandwidth
* Antenna tuners: SWR, bandwidth, frequency
* Amplifiers: input and output matching networks, chokes, suppressors, traps, and components
* Coaxial transmission lines: SWR, length, velocity factor, approximate Q and loss, resonant frequency, and impedance
* Filters: SWR, attenuation, and frequency range
* Matching or tuning stubs: SWR, approximate Q, resonant frequency, bandwidth, impedance
* Traps: Resonant frequency and approximate Q
* Tunes circuits: Resonant frequency and approximate Q
* Small capacitors: Value and self-resonant frequency
* RF chokes and inductors: Self resonant frequency, series resonance, and value
* Transmitters and oscillators: Frequency
สนใจติดต่อ เบอร์โทรข้างล่างครับ
0860343635 (บัณฑิต  สุวงศ์)อี๊ด
MFJ 259B HF/VHF SWR Analyzers สำหรับท่านที่สนใจ ได้ในราคา 10500+EMS บาท
ซองใส่ด้วย ได้ในราคา 1200 +EMS บาท
MFJ MFJ-29C - MFJ Antenna Analyzer Carrying Cases
สินค้าแต่ละชิ้นจะได้รับของภายใน 30 วัน และจะต้องมัดจำ ครึ่งหนึ่งก่อนครับ
เป็นสินค้าใหม่
ชื่อ บ/ช : นายบัณฑิต  สุวงศ์
ธนาคารกรุงไทย :สาขา มหาวิทยาลัยธรรมศาสตร์ ท่าพระจันทร์
เลขที่ บ/ช :981-6-68887-5
บัญชี : ออมทรัพย์
« แก้ไขครั้งสุดท้าย: 03 มิถุนายน 2014, 11:24:12 โดย banhdit » บันทึกการเข้า
✿ทานตะวัน151✿
กระทู้: 27359
« ตอบ #1 เมื่อ: 03 มิถุนายน 2014, 11:43:21 »
อยากได้คับแต่รอนานจัง
banhdit
กระทู้: 245
« ตอบ #2 เมื่อ: 03 มิถุนายน 2014, 12:32:16 »
30 วัน จริงแล้วของจะถึงประมาณ 20 วัน ผมเผือเวลาเอาไว้ครับพี่
