03 ตุลาคม 2024, 13:30:23 *
หน้า: 1 [2] 3 4 5
ผู้เขียน หัวข้อ: ต้องการขาย icom 208H  (อ่าน 7252 ครั้ง)
somchay
กระทู้: 953
สบ2.
« ตอบ #10 เมื่อ: 15 มีนาคม 2010, 09:20:02 »
IC-208H
VHF/UHF FM Transceiver
specifications
IC-208H
    * features
    * options
    * product images
    * authorized dealers
    * government sales
all downloads
Specifications
General
Frequency coverage
Version    Guaranteed
Range    Tx Working
Range    Rx Working
Range
U.S.A.    144-148,
440-450    144-148,
420-450    118–173.995,
230–549.995,
810–999.990*
General    144-148,
430-440    136–173.995,
400–478.995    118–173.995,
230–549.995,
810–999.990
* Cellular blocked
Mode    FM, FM-N, AM*, AM-N*
* RX only; not guaranteed.
Number of memory channels    512 (including 2 call, 10 scan edges)
Antenna connector    50Ω (SO-239)
Power Supply requirement    13.8 V DC ±15%
Useable temperature range
-10°C to +60°C
+14°F to +140°F
Frequency stability    ±10 ppm (-10°C to +60°C)
Tuning step increments    5, 10, 12.5, 15, 20, 25, 30, 50, 100 and 200kHz
Current drain (at 13.8 V DC)
Receive    Stand-by    0.8A
     Max. audio output    1.0A
Transmit    High (VHF/UHF)    12.0A / 11.5A
Dimensions
(projections not included)
141(W) x 40(H) x 185.4(D) mm
59⁄16(W) x 19⁄16(H) x 75⁄16(D) in
Weight    Approx. 1.2 kg; 2.65lb.
Transmitter
Output power
VHF
UHF
55W, 15W (approx.), 5W (approx.) selectable
50W, 15W (approx.), 5W (approx.) selectable
Max. frequency deviation    ±5.0 kHz (wide), ±2.5 kHz (Narrow)
Spurious emissions    Less than -60 dB
Microphone connector    600Ω (8-pin modular jack)
Receiver
Intermediate frequencies
1st
2nd
46.05 MHz
450 kHz
Sensitivity (at 12dB SINAD)    Less than 0.18 micro V (144/430MHz band only)
Squelch Sensitivity    0.13 µV (at threshold; 144/430MHz band only)
Selectivity (Wide/Narrow)
More than 12/6kHz at -6 dB
Less than 30/20kHz at -60dB
Spurious rejection ratio    More than 60 dB
Audio output (at 13.8 V DC)    More than 2.0 W at 10% distortion with an 8Ω load
Ext. speaker connector    2-conductor 3.5(d) mm (1⁄8″)/8Ω
Supplied Accessories
    * Hand microphone, HM-133
    * DC power cable, OPC-1132
    * 3.5m (11.5ft) separation cable, OPC-600/R
    * Mounting bracket
    * Spare fuse
http://www.icomamerica.com/en/products/amateur/mobile/208h/specifications.aspx
โปรดพิจารณาให้ดีซื้อแล้วไม่รับคืน
0817575075
Godzila
กระทู้: 155
« ตอบ #11 เมื่อ: 15 มีนาคม 2010, 09:42:26 »
kington 200 ได้ป่ะคับ
เดี่ยวไปรับเองที่สระบุรี
คับ...PM~หน่อยคับ
HAMTRANG
กระทู้: 889
ของถูกมักไม่ดี...ของดีก็ไม่ถูก...
« ตอบ #12 เมื่อ: 15 มีนาคม 2010, 10:17:09 »
kington  ยังอยู่อีกมั้ย ติดต่อ PM กลับด้วยจร้า
Tel 08-74706448
เมืองตรังรังสฤษแม้น เมืองสวรรค์. ตรังมุ่งทำดีกัน ทั่วหน้า. ศรีตรังเด่นดอกพันธ์ พราวถิน. ตรังแต่งตรังคู่หล้า อยู่ยั้งตรังเสถียร
อัดอเมซอล
กระทู้: 721
« ตอบ #13 เมื่อ: 15 มีนาคม 2010, 10:25:42 »
ไม่เห็นมีเบอร์โทรเค้าเลยครับ
นายอรรถวิชชาญ  อ้นเพียรเอก  91/2 ต.หนองแค อ.หนองแค จ.สระบุรี 18140   080-6668503  AIS
ธ.กรุงไทย  สาขาหนองแค  บัญชีออมทรัพย์  เลขบัญชี125-0-28168-7
attawichan(แอท)gmail.com
somchay
กระทู้: 953
สบ2.
« ตอบ #14 เมื่อ: 15 มีนาคม 2010, 15:16:56 »
เพิ่มรูปครับ
somchay
กระทู้: 953
สบ2.
« ตอบ #15 เมื่อ: 16 มีนาคม 2010, 12:42:35 »
จองไว้ไม่มาเอาขายต่อครับ
somchay
กระทู้: 953
สบ2.
« ตอบ #16 เมื่อ: 17 มีนาคม 2010, 15:11:55 »
ยังไม่ได้ขายครับ มาดูตัวแล้วยังไม่ตกลง
somchay
กระทู้: 953
สบ2.
« ตอบ #17 เมื่อ: 24 มีนาคม 2010, 07:28:12 »
ขอ up หน่อย
pong55555
กระทู้: 1685
« ตอบ #18 เมื่อ: 24 มีนาคม 2010, 08:05:36 »
ลดได้ป่าว หรือรับแลกกับเครื่องรุ่นอื่นหรือไม่ครับ
ปอง
Tel no. 089-663-9097 (DTAC)
nrasert
กระทู้: 2851
« ตอบ #19 เมื่อ: 24 มีนาคม 2010, 13:27:35 »
ยังสนใจอยู่นะครับ สกลนครครับ
หน้า: 1 [2] 3 4 5
