06 ตุลาคม 2024, 23:14:56 *
ผู้เขียน หัวข้อ: เครื่องรับ Scanner Radioshack Pro433  (อ่าน 547 ครั้ง)
gipgi
กระทู้: 677
« เมื่อ: 09 ตุลาคม 2013, 08:12:35 »
เฉพาะตัวเครื่องไม่มีสาย DC สภาพดีมากพร้อมใช้ ราคา 3,900 บาทพร้อม EMS
Frequency
Frequency Range (MHz)
 29-54
 108-136.9875
 137-174
 179.75-215.75
 216-224.9950
 225-399.9875
 400-512
 806-956        excluding cell
 1240-1300
Features
Can be updated to support Rebanding? NO
4 different channel plans can be selected in Motorola trunking menu - not documented in manual
Multi-mode trunking (VHF, UHF, 800, 900, Motorola I/II/IIi, EDACS, LTR)
Motorola Control Channel Only scanning option in menu with selectable plan for 800/900 mHz systems but only one site or system can be programmed per bank
Military Air
Signal stalker I (with 10 autostore channels)
Triple-Conversion Circuitry
1,000 Channels in 10 banks
Ten Scan Lists
Weather Search
Weather Alert Indicator
SAME-FIP Digital Weather Alert
Two Second Scan Delay
ID Delay
EDACS Partial Talkgroups
Lock Out Function
200 Search Lockouts
10 Priority Channels
10 Priority IDs per bank
Four Service Banks - Police, Aircraft, Ham, and Marine
Hypersearch
Hyperscan
Direct Search
Key Lock
Memory Lock
Data Signal Skip (skips no-modulated or data signals)
Disconnect Tone Detect (scanner tunes into data trunk channel when it receives a disconnect transmission)
Status Bits
Manual Access
Liquid Crystal Display
Display Backlight-On, Dimmer, Off
Key Backlight
BNC Antenna connector
Memory Backup
Programming from PC/MAC (not controllable)
Key tones (for correct entry or different tones for errors)
Can be cloned from the Pro-160,Pro-162 or another Pro-433 with a 1/8" to 1/8" mono cable.
RR System Compatibility
This scanner is compatible with the following Trunking System Types and System Voices used in the RadioReference Database, of course you must verify that the scanner will cover the appropriate frequency range:
System Types:
Motorola Type I
Motorola Type II
Motorola Type IIi Hybrid
Motorola Type II Smartnet
Motorola Type II Smartzone
Motorola Type II Smartzone Omnilink
EDACS Standard (Wide)
EDACS Standard Networked
EDACS SCAT
LTR Standard
« แก้ไขครั้งสุดท้าย: 16 พฤศจิกายน 2013, 08:25:11 โดย gipgi » บันทึกการเข้า
gipgi
กระทู้: 677
« ตอบ #1 เมื่อ: 22 ตุลาคม 2013, 08:03:10 »
สนใจต่อรองราคาได้นะครับ
gipgi
กระทู้: 677
« ตอบ #2 เมื่อ: 22 ตุลาคม 2013, 11:43:47 »
up
gipgi
กระทู้: 677
« ตอบ #3 เมื่อ: 16 พฤศจิกายน 2013, 08:25:30 »
ยังขายอยู่ครับ
