01 กรกฎาคม 2024, 16:31:07 *
ผู้เขียน หัวข้อ: Radioshack Pro107  (อ่าน 845 ครั้ง)
gipgi
กระทู้: 677
« เมื่อ: 01 ตุลาคม 2013, 09:12:24 »
Radioshack Pro107 สภาพดี พร้อมใช้งานประกอบด้วย ตัวเครื่อง คู่มือแท้ CD สาย USB ซองเหน็บเอว เสา อุปกรณ์ของแท้ทุกชิ้น ราคา 4,250 รวม EMS
 คู่มือ http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000107_PM_EN.pdf
Operating voltage
DC 2.4 Volts (“AA” cell x 2pcs. Ni-MH Batteries)
DC 3 Volts (“AA” cell x 2pcs. ALKALINE Batteries)
Ext. power and charge voltage USB Power (DC 5V 500mA)
Object oriented memory management. See the Object Oriented Scanning Described article for more information
Number of conventional channels, trunked systems, sites-per-system, and talkgroups-per-system limited only by available file space on the SD Card
Full duplex support and USB connection using the supplied USB Scanner Data Manager Cable, however it will not access the SD card in the radio.
Object programmable display alert (including multi-pattern flashing) to assign to talkgroups, frequencies, agencies, etc.
Non need for a traditional keypad, radio uses media player style buttons to navigate to user programmed playlists.
Play List; create a scan list tailored to your favorite object settings from the Radioreference database.
Navigate using the button operations to get to the play list set.
Signal Stalker II Near field frequency capture
Triple conversion
Simple display option will display object and playlist only, or disabled for more detailed display
SD Preprogrammed with entire USA Radioreference database, additionally can use High Capacity Secure Digital Cards as long as 32kB memory block clusters are used.
Programmable audible alarms
Easy-to-read back display and back lit keypad
Display and keypad backlighting can be turned on or off independently
Scan rate 75 channels per second (non trunking)
Search speed 85 channels per second
CTCSS/DCS abilities with search, however has no autosave or keypress save feature. V1.3 and later firmware allow saving of a tone via keypress in Menu.
16-character alpha-tagging with text entry can show ID code or service name
Temporary and permanent L/O of talkgroup ID or frequency
ID delay
UNSQUELCH Delay; Delay settings before the radio unmutes audio to speaker
Motorola Control Channel Only trunking
Radio ID Display
Priority Object settings (conventional and Trunked)
6 search ranges/ 1 user definable search range
Search "seek" feature
Tunes virtually all important bands—local marine, fire/police, Ham, CB, VHF-air, UHF-Air, racing, weather and more
Weather band with enhanced SAME Weather Alert functions and weather priority—access weather channels and alerts with the push of a button
Skywarn list can be programmed with any number of "objects"
"Multiple" Priority channels
Zeromatic search tuning
20db attenuator, can be set globally
Computer interface and Programming
9 navigation keys to access special modes and programming options
6 line x 16 character display with relative signal strength meter
BNC connector
Internal battery charger, with power from the supplied PC/IF->USB cable or an external USB power AC or DC converter.
PC/IF data output when enabled. Works with analog trunked systems and conventional data. See the Control and monitoring software section.
USB to serial cable has Uniden style connector for PC/IF. No access to SD card remotely. An SD card reader is not supplied.
Programmable Welcome Screen text
Browsing to objects and pausing on them is supported
Problems experienced with this scanner by purchasers:
Glitchy software. Latest updates are more stable than original release but software is still not 100% stable.
Battery indicator unreliable.
Signal meter not visible on "playing" screen. No way to indicate if trunk system is getting signal.
LCD screen goes blank in two scenarios;
when light is left on for an extended period of time.
when unit is used reguarly. Possible faulty LCD screens are being used in this scanner.
No belt clip with scanner.
No power port other than using a USB cable.
No lock out button function. On many occassions the scanner buttons will easily be pushed to stop scanning during normal carry.
Update database not updated instantly. Documented as many as 8 days between update and what was listed on Radio Reference.
Stock antenna is useless, more so than any other stock rubber-duck ever experienced. Might as well come without one.
Poor support from Radio Shack per customer experiences of picking up the telephone and calling them. No infomation for e-mail support experiences.
Scanner รุ่นอื่นๆดูเพิ่มเติมที่นี่ครับ
https://www.facebook.com/pages/Scanner/219525118183660
« แก้ไขครั้งสุดท้าย: 01 ตุลาคม 2013, 14:46:55 โดย gipgi » บันทึกการเข้า
gipgi
กระทู้: 677
« ตอบ #1 เมื่อ: 01 ตุลาคม 2013, 11:16:10 »
มีระบบ Signal Stalker ค้นหาความถี่ใกล้เคียงได้ภายในเวลาไม่กี่วินาทีครับ
gipgi
กระทู้: 677
« ตอบ #2 เมื่อ: 01 ตุลาคม 2013, 16:32:05 »
up
gipgi
กระทู้: 677
« ตอบ #3 เมื่อ: 01 ตุลาคม 2013, 21:48:14 »
Up
gipgi
กระทู้: 677
« ตอบ #4 เมื่อ: 02 ตุลาคม 2013, 10:57:41 »
ยังขายอยู่ครับ
gipgi
กระทู้: 677
« ตอบ #5 เมื่อ: 02 ตุลาคม 2013, 19:06:01 »
up
pop smith
กระทู้: 637
« ตอบ #6 เมื่อ: 02 ตุลาคม 2013, 22:12:46 »
Alinco DJ X3  ยังขายอยู่ไหม  ครับ   ป๊อป  081-7262851
