01 ตุลาคม 2024, 11:48:28 *
ผู้เขียน หัวข้อ: ขายเครื่องชาร์จถ่านอัลคาไลน์ ช่วยประหยัดค่าถ่านได้หลายตัง  (อ่าน 482 ครั้ง)
gipgi
กระทู้: 677
« เมื่อ: 22 พฤษภาคม 2013, 09:12:43 »
ขายเครื่องชาร์จถ่านอัลคาไลน์ ช่วยประหยัดค่าถ่านได้หลายตัง ของใหม่ทดสอบแล้วชาร์จได้จริงๆครับ 1,700 พร้อม EMS ครับ
Product Description
This fantastic device not only regenerates dead Alkaline batteries, it recharges several common rechargeable batteries as well, helping you save money and reduce waste. You can even charge or regenerate mixed battery sizes at the same time!
BRAND NEW professionally boxed & sealed.
12 months Warranty
Easy to Use !
Charges Four (4) kinds of batteries NIMH, NiCad, RAM & Alkaline
4 Charging slots 4AA, 4AAA, 4 D cell, 4 C cell, 1 x 9v slot
Australian Safety Tested approved 240v power plug
Four fully Independent charging circuits allows you to charge cells individually, 1,2,3 or 4 batteries at one time.
Has discharge function for NiCad batteries.
Short circuit protection.
Using both LED & LCD displays the status of each battery can easily be seen.
Save HUGE $$$$ as rechargeable batteries can be recharged hundreds of times.
Excellent performance in Digital Cameras, Toys, CD Players, Remote Control Devices, Metal Detectors, Flashlights, Walkmans, PDAs, Radios.....Absolutely anything.
Memory free operation means convenience......no need to fully drain/discharge NIMH batteries before charging.
Intelligent Micro processor controls ideal charging. Independent circuit detects the charge of each battery individually.Negative Delta V detects full battery charge & reduces to trickle rate to prevent battery damage.
LCD (Liquid Crystal Display) screen provides full battery & charging status including Power on/off, Charging, Charge Complete, Trickle Mode, Bad Battery Indicator, Over-Temp Indicator,Cell # & Percentage each cell is currently charged.
It has advanced circuitry inside to monitor charging through voltage drop & the cell's internal resistance, so that you'll get fuller charges and eliminate damage from overcharging of simpler cheaper chargers. In other words, your NiMH cells will give you better performance as well as a longer service life.
Lithium Free NIMH cells are environmentally friendly.
Battery protection - charger protects against overcharge, overheat, short-circuit and polarity-reversal issues
Advanced processor control - for plug-and-go operation
LED indicator - turns off when charging/regenerating process is complete
Get more life out of batteries you would otherwise throw away - saves money and helps reduce waste
Charger specifications:
Input: 12v--1A
Output: 4 x (1.2v--850MA)
           4 x (1.5v--130MA)
           4 x (9v ---400MA)
Charge Time Reference (1-4)Pcs
Size Approx Charge Time
Ni-Cad         Ni-MH                 Alkaline
AA 1.4hr      AA 2.0hr              AA 5.0hr
AAA 0.7hr    AAA 1.4hr            AAA 2.5hr
C 3.9hr        C 6.0hr               C 6.0hr
D 7.7hr        D 8.0hr               D 10hr
9V 6.0hr
คู่มือครับ
« แก้ไขครั้งสุดท้าย: 25 พฤษภาคม 2013, 10:49:16 โดย gipgi » บันทึกการเข้า
gipgi
กระทู้: 677
« ตอบ #1 เมื่อ: 25 พฤษภาคม 2013, 10:49:51 »
ยังขายอยู่ครับ
