เข้ามา 1 ตัว ครับ หูฟังแนวสปอร์ตไร้สายเชื่อมต่อด้วยบลูทูธ สีฟ้าสดสวย ของใหม่ 650 บาท รวมส่งลงทะเบียน
หากอีเอ็มเอส เพิ่มอีก 50 บาท ครับ
มาดูสเปคกันครับFeatures:
100% Brand New and High Quality
Easy to use
Portable back-hang design, convenient for sports
Allow you answer the phone anytime and anywhere
Specifications:
Color: BLUE
Buttons: Play/ Pause, VOL +, VO -, Call/ Receive
Talk time: 4 hours
Standby time: 100 hours
Dimension: About 14.5 x 13.5 cm
USB Cable Length: About 62 cm/ 24.8''
Support Format: MP3 WMA WAV
Support System: Windows 98 / 2000 / XP / Vista
Mini USB IN
Built-in lithium battery (charged via USB)
Built in Microphone for Handsfree Cell Phone use
Only Listen to music to Nokia phone
Can answer calls from any phone
Material: Plastic & Rubber
Quantity: 1 Set
Note:It is not suitable for Iphone phone.
Please read the following tips when you are using the Bluetooth headset:
1. Charge the headset:
Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically.
2. Turn on the headset:
Press the on / talk button on the headset (the middle button of the three) for 5 seconds, the light on the headset flashes quickly for 3 times of green, continue pressing another 5 seconds until it totally on( the light flashes green and red), now the headset is ready to be connected to the Bluetooth device.
3. Connect:
Turn on the Bluetooth function on your Bluetooth device (mobile phone...) and search the matching device, select the LSD-5011D for matching, and enter matching password "0000", after matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the middle button, you can talk with Bluetooth headset, when you want to end the call, press the middle button, you can end the call.
5. Turn off the headset: Press the on / talk key(middle button) for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.***มาชมภาพกันครับ***
