ขาย yaesu vx-1 ใหม่ๆ ขาย 3999บาทส่งลงทะเบียนฟรี หรือเพิ่ม100บาทส่งแบบEMS ของอยู่ มีนบุรี กทม 0886074166
ข้อมูลเกี่ยวกับผลิตภัณฑ์
โปรดศึกษาให้เข้าใจก่อน
VX-1R Specifications
GENERAL
Frequency Range Receive: 0.5 - 1.7 MHz (“BC BAND”)
0 76 - 108 MHz (“FM”)
0 108 - 137 MHz (“AIR”)
0 137 - 170 MHz (“V-HAM”)
0 170 - 222 MHz (“VHF TV”)
0 222 - 420 MHz (“ACT 1” Action Band 1)
0 420 - 470 MHz (“U-HAM”)
0 470 - 800 MHz (“UHF-TV”)
00 800 - 999 MHz (“ACT 2” Cellular Blocked)
Frequency Range Transmit: 137 - 174 MHz
0 430 - 450 MHz
Channel Steps: 5/10/12.5/15/20/25/50/100 kHz
Frequency Stability: 5 ppm (-10° C to +60° C)
Repeater Shift: 600 kHz (VHF)
0 1.6/5.0/7.6 MHz (UHF)
Emission Type: F3 (G3E), F2
Antenna Impedance: 50 Ohms, unbalanced
Supply Voltage: Nominal: 3.6 V DC, negative ground
Operating: 3.2 - 7.0 V, negative ground (EXT DC jack)
Current Consumption: 150 mA (Receive)
0 50 mA (Standby, Saver Off)
0 16 mA (Standby, Saver On)
0 200 mA (Auto Power Off)
0 0.4 A (500 mW TX, VHF/UHF)
Operating Temperature: -20°C to +60°C
Case Size: 47 (W) x 81 (H) x 25 (D) mm (w/o knob & antenna)
Weight: 125 g. (Approx., w/ant. & battery)
RECEIVER
Circuit Type: Double-conversion superheterodyne (VHF/UHF)
Superheterodyne
IFs: 1st: 41.45 MHz (VHF/UHF)
0 455 kHz (0.5 - 1.7 MHz)
IFs: 2nd: 450 kHz (Narrow FM)
0 10.7 MHz (Wide FM))
Sensitivity: 0.16 V for 10dB SINAD (144 - 148 MHz)
0 0.18 V for 12dB SINAD (430-450 MHz N-FM)
Selectivity (-6dB/-60dB): 15 kHz/35 kHz (Narrow FM)
AF Output: 50 mW (แอท) 8 Ohms for 10% THD ((แอท) 3.6 V DC)
AF Output Impedance: 8 Ohms
0
TRANSMITTER
0
RF Power Output: 1W ((แอท) 6 V EXT DC Input)
0 500 mW ((แอท) 3.6 V DC)
Modulation Type: Variable Reactance
Maximum Deviation: ฑ5 kHz
Spurious Emission: At least 50 dB below carrier
Microphone Impedance: 2 k Ohm
0
Specifications are subject to change without notice and are guaranteed within amateur bands only.
Frequency ranges and repeater shift vary according to transceiver version.
ตัวเดียวไปได้หลายย่าน
อุปกรณ์ประกอบด้วย
1.ตัวเครื่องแท้พลาสติกปิดจอยังอยู่ เครื่องไม่ติดเจ ham uhf fm am tv airband อื่นๆ
2.แบตเตอร์รี่แท้
3.เสา 144/245/430
4.หม้อแปลงชาร์จ ใช้งานได้ปรกติ by hondaone
5.สายคล้องมือแท้ยังไม่ได้แกะออกจากถุง
6.คลิปหนีบพร้อมน๊อตแท้ยังไม่ได้แกะออกจากถุง
บอร์ดหน้า411+ไมค์+สายแพรใช้ได้ จอดำ ขายไปตามสภาพขาย 350 ชลบุรีจอง
บอณดหน้า2gxet-t พร้อมจอ ลำโพง ไมค์ สายแพน้ำตาล จอสวยไม่ดำ ขาย 800บาท ชลบุรีจอง
