25 พฤศจิกายน 2024, 11:39:38 *
ผู้เขียน หัวข้อ: จำหน่าย PowerMaster II Station Monitor, VSWR & RF Power Meters  (อ่าน 9387 ครั้ง)
tenmetershop
กระทู้: 1425
« เมื่อ: 21 กันยายน 2012, 18:30:30 »
ราคา 25,500.- สนใจติดต่อ 081-5580422 K.มนตรี
<a href="http://www.youtube.com/watch?v=qZUe0tcXZGw" target="_blank">http://www.youtube.com/watch?v=qZUe0tcXZGw</a>
Some of the Many Features
 ALC-1 - ALC protection option, shuts down your transmitter fast but yet allows ALC normal operation
 FASTEST Bar graph on the Market, makes tuning an amp or a tuner a joy, faster than an analog meter. So fast it can catch the first "dit" at 99 WPM and even show you if your rig has a RF spike problem.  Why mess around with other meters that have have had display failures?
 Displays VSWR, Power, and Bar graph at the same time.
 Runs with or without a PC connected to it. That means there are no programming hassles and issues setting this meter up. Runs right out of the box.
 Accuracy typically better than +/- 3% over frequency and temperature ranges
 Commercial couplers available for VHF and UHF commercial bands
 Peak Hold Modes – programmable for fast(1/2 sec), medium, slow, and Long ( 5 sec) for CW, SSB, data, FM, whatever you're sending!
 Two Models – 3 kW and 10 kW - standard coverage is 160 through 6m (1.8 to 54 MHz)
 Separate Display and Coupler/Sensor boxes–  Sensor can be remotely located at your amp or in your mobile unit this also keeps the high power cables away from your radios, audio equipment, PCs etc.  No nasty RF cables on top of your desk or radio to cause RFI and other clutter issues! The coupler is using DC only, no RF is sent to the meter. A good thing!
 Remote use, even 100 feet of cable between sensor and display has no drop in power measurement. None.
 Multiple couplers on one display - the PM II supports two couplers without any external adapters.
 VSWR Alarm – programmable trip point, LED and Relay – Can shut down your amp fast!
 Power Alarm -  programmable trip point, LED and Relay - Alerts you that your amp has tripped out
 Alarms can maintain until manually reset, or you can program an auto alarm reset
 Bar Graph – Operates in two modes, Auto Ranging Power and VSWR you can peak your amp sending dots or talking into a mic, or dip your VSWR with your tuner using dots. Easy on the tubes and efficient.
 Bar Graph in Power mode – Auto Ranging in user selectable ranges – Easy to read
 Large LCD Display – Easy to read even in bright sunlight - low energy consumtion
 Programmable from front panel or via USB or RS232 – Even display your call letters in it too!
 Free Application for your PC - Will allow remote user’s full use of meter even on the internet
 All Metal Boxes – Rack Mount Options available, 1 or 2 units in a 19” 2U panel
 Choice of connectors, SO239, Type-N, and 7/16 DIN
 Display Head Size 7” X 3 3/4" Face, 4 1/2” Deep
« แก้ไขครั้งสุดท้าย: 11 มีนาคม 2013, 23:33:35 โดย tenmetershop » บันทึกการเข้า
จำหน่ายวิทยุสื่อสารและอุปกรณ์
www.tenmetershop.com
tenmetershop
กระทู้: 1425
« ตอบ #1 เมื่อ: 21 กันยายน 2012, 23:28:42 »
เพิ่มเติมสำหรับวัดย่าน 144MHz
http://m.youtube.com/watch?v=uWuzs63l-JI
« แก้ไขครั้งสุดท้าย: 21 กันยายน 2012, 23:34:05 โดย tenmetershop » บันทึกการเข้า
tenmetershop
กระทู้: 1425
« ตอบ #2 เมื่อ: 28 ตุลาคม 2012, 09:38:11 »
YAESU
YAESU FT-258 (VR)     ราคา 4,990.-
YAESU FT-250R         ราคา 4,490.-
YAESU FT-270R         ราคา 5,200.-
YAESU FT-60R          ราคา 6,900.-
YAESU VR-160          ราคา 8,500.-
YAESU VX-3R           ราคา7,200.-
YAESU VX-6R           ราคา 10,500.-
YAESU VX-7R           ราคา 13,500.-
YAESU VX-8DR          ราคา 16,500.-
YAESU VX-8GR          ราคา 15,500.-
YAESU FT-817ND        ราคา 25,000.-
YAESU FT-1900R        ราคา 5,800.-
YAESU FT-2900R        ราคา 6,500.-
YAESU FT-7900R        ราคา 10,500.-
YAESU FT-8800R        ราคา 15,500.-
YAESU FT-8900R        ราคา 17,500.-
YAESU FTM-10R         ราคา 13,500.- ของหมดครับ
YAESU FTM-350AR       ราคา24,000.-
YAESU FT-857D         ราคา 29,999.-
YAESU FT-897D         ราคา 32,000.-
YAESU FT-450D         ราคา 39,000.-
YAESU FT-950           ราคา 58,000.-
YAESU FT-2000         ราคา 99,000.-
YAESU FT-2000D       ราคา 132,000.-
YAESU FT DX-5000D   ราคา 199,800.-
YAESU FT DX-9000D   ราคา 420,000.-
YAESU FT DX-3000 HF/50MHz ราคาเร็วๆนี้ครับ.-
tenmetershop
กระทู้: 1425
« ตอบ #3 เมื่อ: 10 สิงหาคม 2016, 12:56:16 »
http://www.tenmetershop.com/
tenmetershop
กระทู้: 1425
« ตอบ #4 เมื่อ: 15 มีนาคม 2017, 15:44:09 »
tenmetershop
กระทู้: 1425
« ตอบ #5 เมื่อ: 26 พฤศจิกายน 2021, 13:44:45 »
