SPECIFICATIONS
Type: Amateur VHF/UHF transceiver
Frequency range: TX: 144-146 / 430-440 MHz (Europe)
TX: 144-148 / 222-225 / 430-450 MHz (USA)
RX: 0.504-999 MHz (Cellular blocked in the US)
5/9/10/12.5/15/20/25/50/100 KHz steps
Mode: TX: FM
RX: AM/FM/WFM
RF Power output: 2m/70cm Hi: 5/5 W, Low3: 2.5/2.5 W, Low2: 1/1 W, Low1: 0.3/0.3 W
220 MHz Hi: 1.5 W, Low3: 1 W, Low2: 0.5 W, Low1: 0.2 W
Receiver system: N/A
Sensitivity: 0.5-30 MHz, AM: 3 uV (10 dB S/N)
VHF low, NFM: 1 uV (12 dB SINAD)
140-150 MHz, FM: 0.16 uV (12 dB SINAD)
400-470 MHz, FM: 0.18 uV (12 dB SINAD)
Selectivity: AM/NFM: 12 KHz (-6 dB), 35 KHz (-60 dB)
WFM: 200 KHz (-6 dB), 300 KHz (-20 dB)
Image rejection: N/A
Voltage: 7.4 VDC (nominal), 5-16 VDC (external)
Current drain: RX: 20-150 mA
TX: Max 1.8 A
Impedance: 50 ohms, SMA
Dimensions (W*H*D): 58*89*29 mm
Weight: ? gr
Manufactured: 2005-201x
Other: 1000+ memories with alpha-tags. CTCSS/DCS, DTMF, ARTS.
Built-in temperature sensor. WIRES-compatible. CW training feature.
Password protection. Waterproof/submersible
Related documents: User manual (2.7 MB)
Modifications:
Options/Accessories:
ADMS-VX6
CMP-460A
CD-15A
CSC-91
CT-91
EDC-5B
EDC-6
FBA-23
FNB-80LI
MH-57a4b
MH-73a4b
SU-1
VC-24
VC-27 Programming kit, software and USB cable
Waterproof speaker microphone
Lithium-Ion 2.5 hours rapid charger
Vinyl carrying case
Mic adapter
DC cable with voltage regulation and cigarette lighter plug
DC cable only
Dry cell case (2*R6/AA)
Lithiom-Ion pack, 7V 1500 mAh
Speaker microphone
Barometric pressure sensor unit
VOX headset
Earpiece microphone
ตัวนี้ไม่ติดเจนะครับ
เชิญประมูล YAESU VX-6 ปิดเวลา 22.23.24 น. วันที่ 17 กันยายน 2555
