(2)3-500z Collectors condition Located in pattaya chonburi 55,000baht 089-229-1482 eng 089-2341843 thai email hs0zju gmail.com
Drake L4B Linear Amplifier & L4PS Power Supply Amateur Ham Radio
You will be very satisfied with this unit
I have gone thru this unit top to bottom and it is in very good condition
I have gone ahead and installed all two HARBACH Mods, including
1. PM-400 Replacement Power Module
2. SK-401 Soft-Key
Powered up and meter shows 2500 Volts on the plate in SSB, 1750 in CW
No odors, Cleaned and lubed
Wired for 210 Volts
Relay contacts are A1 condition
All the controls are tight and works fine
The Plate Vernier control works perfect
It has been well taken care of and is in peak performance
However, no guarantee is made, and the unit, like all vintage equipment, is sold "as-is."
As you can see from the photographs, the unit is in very good shape
