ขายอีก 1 ตัว Switching Power Supply 23 Amp ของเก่าเก็บ ราคา 3,500 บาท.
รูปแทน
Model No. SEC-1223
Input Voltage (Nominal) 120 VAC, 60 Hz
Output Voltage 13.8 VDC
Output Ripple & Noise (ON FULL LOAD, PEAK TO PEAK) 150 mV
Output current, Continuous 23 A
Current Limit 25 A
Cooling Temperature controlled fan
Protections
Over current, short circuit and over voltage (through PWM controller),
over temperature shut down
Environmental Temperature range 0 - 40°C
AC input Detachable power cord C/W NEMA 5-15P plug
DC input Terminals with tubular hole DIA. 0.2” (5 mm) with set screw
Fuse Rating 5 mm x 20 mm Glass fuse, 125 V or 250 V (Time delay / slow blow), 6.3 A
Bussmann GDC-6.3
Littelfuse 21806.3
Dimensions, mm (L x w x h) 178 x 211 x 56
Dimensions, INCHES (L x w x h) 7 x 8.3 x 2.2
Weight, KG 1.59
Weight, LB 3.5
Safety certification CULUSA Listed, UL60950-1, E179076
EMC Conformity FCC Part 15(B), Class B Digital Device
