TYT TH-9000 ด้วยกำลังส่ง 65-100 Watt ของเรามีพัดลมติดตั้งมาจากโรงงาน
ราคา 4,xxx บาทโทร.
080-0581121 24 ช.ม.
SPECIFICATION
Model ................................................. TH-9000
Working temperature ............................ -20~+60℃
Rated Voltage ..................................... 13.8V DC±15%
Output power ...................................... ≤45W/60W
Color .................................................. Black
Dimension(L×W× > .............................. 145x50x190mm
Weight ................................................ 1830g
Hot Spots
Dual band or Single band ....................... Single band
Dual or Single frequency ........................ Single frequency
Mode .................................................. FM radio
launch Frequency range .......................... VHF: 136-174MHz
Memory Channel ................................... 200
CTCSS/DCS function .............................. 50 CTCSS / 1024 DCS
Channel step ....................................... 5/6.25/10/12.5/15/20/25/30/50KHz
Wide/Narrow Band ............................... Yes
Voice pressure /expansion function ......... Yes
Repeater offset shift ............................ Yes
Contact book ...................................... Yes
ANI ID ............................................... Yes
DTMF/2 tone/5 tone coder .................... Yes
Remote kill/ stun/ activate/ revive ........ Yes
Keypad lock function ........................... Yes
0-9 SQL grade setting ......................... Yes
1750MHz tone .................................... Yes
Reverse frequency ....................... Yes
Auto Power off ................................... Yes
Scrambler function .............................. Yes
VOX function ...................................... Yes
Busy lockout function ........................... Yes
Scanning function ................................ Yes
Monitor function ................................. Yes
TOT function ...................................... Yes
Battery voltage display ........................ Yes
Channel name display/editing ................ Yes
Emergency alarm ................................. Yes
Keypad lock function ............................ Yes
FM radio ............................................ Yes Power saving function ......................... Yes
High/Low TX power selectable .............. Yes VHF-60W/25W/10W
Chinese and English voice prompt ......... Yes
PC software programmable ................... Yes
Frequency stability .............................. ±2.5ppm
Adjacent channel selectivity( w/n) ........ 60dB(แอท)12.5KHz/70dB(แอท)25KHz
Modulation ( w/n ) ............................... 11kΦF3E/16kΦF3E
Spurious radiation ............................... <-60db
Sensitivity ......................................... 0.25V/0.35V
Intermediate frequency ....................... 38.85/46.05MHz
Modulation distortion .......................... <5%
FM noise ........................................... ≥40dB(แอท)25KHz /≥45KHz (แอท)12.5KHz
Audio response .................................. +1-+3dB
Audio Distortion ................................. <5%
Inter modulation(w/n) ......................... ≥60dB/≥65dB
Spurious rejection ............................... >60db
กำลัง ดูอยู่ รุ่นเก่าไม่รู้ว่ามีเมนูนี้ไหม FM radio อยู่ที่เมนูเท่าไหร่ อาจจะเป็นเวอร์ชั่นใหม่ป่ะครับ
