ตัวไหนหน้าใช้กว่ากันจะเอามาขับmotorola MARATRAC ตอนนี้ออกที่150+Power Supplys Diamond GSV3000
Dimensions:250Wx150Hx240Dmm
Weight:9kg
30A(continuous)/34A(intermittent)
Input voltage:AC220V 6.5A(50,60Hz)
Output voltage:DC1V to 15V variable
Output current:30A(continuous)(13.8V)(8hours), 34A(intermittent)
(1 min. on and 1 min. off)
Built in Dc cooling fan
Power Supplys Diamond GZV4000
•Size: 8.25" x 13" x 4.5"
•40 Amp Continuous Rating, 100% Duty Cycle.
•Variable Voltage Control 5-15 VDC.
•Voltage Control Knob has center detent at 13.5 VDC.
•Overload & short-circuit protection with Current Foldback at approximately 42 Amp.
•Over Temperature Protection.
•Meter Selector allows monitoring of voltage & current.
•Access to front panel DC Terminals and Cigarette Lighter Jack. Standard 40A terminals on rear panel.
•Built in Speaker.
•Circuitry yields high RFI protection from external sources.
•AC line filter for EMI protection.
•Standard 3-wire Heavy Duty line cord.
•Power Indicator & Overload Indicator.
•Accepts 220 VAC ? 20% 50-60 cps.
•Ripple & Noise less than 8 mV r.m.s.
•Weight: 9 lbs.
